Australia/Queensland Territory hybrid Download.
Postby Garyh » 14 Apr 2016, 10:12
Hi, Iam downloading the above mentioned file at 5800GB but is heading to nearly 6000GB. Can anyone tell me why?
Garyh
Re: Australia/Queensland Territory hybrid Download.
Postby Tonio » 27 Apr 2016, 16:01
Did you try downloading on your PC, then installing it manually on your Android device
http://www.naviate.com.au/hybridmaps/Au ... D.sqlitedb
You get the URL long pressing on the map name in the Map Library
It tell me 6,32 Go
Have saf flights
Postby Tonio » 27 Apr 2016, 22:18
The fact that amount of data that will transferred is much larger than the file size is normal.
To transfer a file, the file is split in lot of small packets
Each packet is send over Internet in an envelope, with header and info
The packet is in the envelope
On the envelope you have information as:
- destination address (where it go)
- originating address (where it come from)
- packet number (requested by the destination to recompose/reassemble the file)
If packets sent are small, this information could represent a significant volumes of data that will come in addition of the pure file size
That’s probably the reason why
Postby Garyh » 01 May 2016, 21:56
Tonio, tried downloading with laptop plugged into modem and failed at about 500mb.Can select the area I fly in on Google earth and load into FIF ???.
Garyh
Postby Tonio » 02 May 2016, 00:45
Garyh wrote:Can select the area I fly in on Google earth and load into FIF ???.
Hi Garyh
YES, you can make your own maps
and NO (I don't know how to generate maps it with Google Earth and satellite image are not very convenient)
Easiest way (for me) to generate maps is using MOBACS
https://sourceforge.net/projects/mobac/ ... BAC%201.9/
(I 'm still using Mobac version 1.9.6, not 2....)
having launched MOBAC select as Atlas format "RMApsSQlite"
this the format supported by FIF
then select the sourcemap
OpenStreetMap Mapquest is good to start
select the source level you need
1 to 12 or 1 to 13
higher is the zoom level bigger will be the file
select the selection tool "Map" -> Selection Mode -> Polygonal
select the area you need as map
Then save and crate Atlas
Once the file is generated then install it on FIF following user guide instructions
Have fun
Postby Tonio » 02 May 2016, 19:42
Hi Gary
You may try this link
https://www.dropbox.com/s/mv1kr4zn9d6ck ... itedb?dl=0
Its map of the area generated from OpenStreet MapQuest with zoom level 1 to 12
That for the file is much smaller(less than 150 Mo)
The file will may later on be available via the standard Map Library of FIF
Have safe flights
Postby kitercuda » 05 May 2016, 20:22
I just replace external data source for Australia maps. Now there are avaialble at FIF downloads. Thanks to Tonio.
Postby Garyh » 22 Jun 2016, 05:46
Finally got the download all's good. Thanks for all your input and help.Cheers
Garyh
