Regarding the Hardware,
I used the Google Nexus 7 until now and bought a Samsung Galaxy Tab A (T580) last week, as it has a bigger display and should run faster. Testing it, I noticed now that Samsung does not allow you to define external (SD-Card) memory as internal and it looks like running maps from an SD Card creates problems within Fly is Fun. As internal memory is limited to 16GB space would run out quickly with maps installed and a view other apps. Before I return the Tab A and look for a different solution, I wanted to ask in the forum
A) if there is a good, clean and easy solution to the mentioned problem
B) if anyone could recomend a above 9 inch display device that works smooth (in case of an A failure)
thx for any inputs, smile and fly,
Dominik
