Map decluttering
Re: Map decluttering
Postby kitercuda » 10 May 2014, 16:32
Database updated - non ICAO Italian APTs are marked like Not Registered, so it is easy to hide/show them now...
Postby Eliseo » 13 May 2014, 09:41
I like it,
but it can be done for other countries, Spain, France, etc.
Eliseo
Postby Eliseo » 07 Jan 2015, 10:21
In Spain all codes beginning in LE
are AD, the rest are generally ULMs,
no with service and no service.
Another question.
I understand that unchecked it should not be anything on the screen, does it?
Eliseo
Postby kitercuda » 08 Jan 2015, 19:16
1. Did you do for zoom 80km (which you displayed)?
2. Try Customize screen and uncheck Force displaying all user defined items.
Postby Eliseo » 09 Jan 2015, 12:34
Hello.
This issue took him almost a year, may be what I not explain very well matter for english language, I try one last time, and I will wait for someone smarter than my and he better explain it.
All display settings are to uncheck Force displaying all user defined items.
The problem are in all zooms.
1 - I understand that if no framework anything in the boxes should not see anything on the screen.
2 - Why I see IFR points if when I do donwload it under only VFR?.
3 - The APT as "moi1" "pal1" etc. this fields are ultralight, and I think have to appear on screen when the box is checked ultralight.
Best regards :)
Edit.- Sorry the number 2 is an error, I only donwload: Airspaces, WPTs, Airports.
Eliseo
Postby kitercuda » 09 Jan 2015, 16:37
This is an issue. When you uncheck all, all is displayed :D
I will repair it...
Postby Eliseo » 13 Jan 2015, 11:05
You managed to solve part of the problem, but I think you should check your database, which I mentioned in the previous post,.
I tell you to improve implementation, I think it is a major improvement.
One more thing.
You should check "unspecified" ... it means? if you turn it off then nothing appears on the screen. :) :)
Eliseo
