2 finger revolve
2 finger revolve
Postby flyyyer » 28 Oct 2014, 20:06
16.40
Hi Petr.
Only tried this on sim but how do you stop the map revolving when using the 2 fingers to zoom? I always move/zoom map and fly north up.
Re: 2 finger revolve
Postby kitercuda » 29 Oct 2014, 07:04
Hi Peter,
I do not understand your question.
But, I have made some changes in verson 16.41.
- If you set map north-up, zoom by two fingers will work like in versions before 16.40.
- If you set map track-up, you can turn map by two finers.
Postby flyyyer » 29 Oct 2014, 23:05
Hi Petr.
My problem is that I cannot now zoom with 2 fingers, without accidently revolving the map, when I now try to zoom with the 2 fingers. For me, this revolve is not an option I would want by default..... I may use later.....
I used to just zoom in and out with no revolving.
I think you need the option to turn off revolve.
I apologise if this turn off ability is already there and I have missed it.
Postby kitercuda » 30 Oct 2014, 06:14
OK - I will add an option.
Version 16.42...
Postby marpdiaz » 02 Nov 2014, 17:09
HI all,
I dont think i will make use of arbitrary rotation in flight. I am kinda afraid of misreading the screen in some situations.
However, it would be nice to preset the alternate screen direction (activated by longtap on north sign)
Now we have the default (north up) and alternate to track up.
Sometimes I would like to have more choices like:
route leg up, and brg up.
This could be predefined in preferences so after long tap on north arrow it rotates to whatever is set in prefs
(route up, brg up, trk up or allow arbitrary revolving). Long tapping again get it back to default (north up).
blue skies,
Postby kitercuda » 03 Nov 2014, 06:24
OK - I will implement it...
Postby flyyyer » 03 Nov 2014, 22:12
16.42
Thanks for the option to choose map revolve option or not.
So many options to be able to set it up just how you like.
Great stuff...great program, I wouldn't fly without it.
