Nav 2 switching?
Nav 2 switching?
Postby flyyyer » 03 Nov 2013, 21:15
When using the simulator and trying a direct to + a Nav 2 waypoint I can't seem to get or find a way to switch to the second waypoint. I expected this to switch automatically like the route or to be able to tap the small nav dialog to do a manual switch . Can you put me right on this usage.
Re: Nav 2 switching?
Postby kitercuda » 04 Nov 2013, 08:56
I will think, how to do it...
Postby flyyyer » 05 Nov 2013, 12:24
Does the Nav1, then Nav 2 switch work in the air, or is it just a prob on the Sim? I can't get this to switch to the Nav 2 item either automatically or from any key press. I also had expected the ETA/DME to End of "route" (i.e. the 2nd nav waypoint eta/dme) to display as end of "route"? The active waypoint works OK. You may have previously answered....... no problem I can just use a small route anyway. This feature is good for a very quick 2 point guidance though. Just a bit of feedback for you..... PJ
Postby kitercuda » 06 Nov 2013, 14:55
Nav1 and 2 works inthe air, there is no difference...
Nav 2 is very simple - just arrow like NDB. I will make a switch 1 & 2
