ADS-B
Re: ADS-B
Postby rotaxquax » 04 May 2019, 18:28
Hello kitercuda,
if I understand it correct by implementing Stratux
you will deal with the GDL90 protocol?
Thx for info.
harry
rotaxquax
Re: ADS-B
Postby kitercuda » 07 May 2019, 17:51
Yes. Aircraft are displayed from Stratux now (not published yet).
GDL90 protocol is implemented - for Wifi - UDP devices.
Re: ADS-B
Postby Tonio » 10 May 2019, 22:32
Today in Tunis, where I leave, being close to Tunis Airport, I tested ADSB-In using Stratux with Fly Is Fun
It works well !!!
Congratulation Petr
For those that already have a Stratux, the way to proceed is the following
1 – Start the Stratux until you get the green light
2 – on your Android device
- Wifi network chose “Stratux” (you may have to disactivate data connection)
There, you can check with your web browser if its work
- Launch Fly Is Fun
3 – within Fly Is Fun, make sure you can use the Stratux
Short press on the compass rose
Then select “Application settings” -> “Preferences” -> “External data source” -> “Wifi” -> “Stratux”
Within “Stratux” page, select “Use it”
Then back to moving map screen, where you can see aircrafts being around
Just great
For those that doesn’t have a Stratux, you can build it your self in less than 1 hour http://stratux.me/#parts-list for around US$ 150.- or buy one ready to use http://stratux.me/#pre-built-units for around US$ 240.-
Have fun and send some screen copies
Re: ADS-B
Postby vacaap » 12 May 2019, 16:41
Amazing! Thank you very much.
Will there be an option to choose which information will be displayed below the traffic (e.g. callsign, heading, squawk,..., possibly bearing and range from your position (or from a bullseye or other chosen points/vor/...))?
Thanks again.
best regards
vacaap
Re: ADS-B
Postby kitercuda » 20 May 2019, 19:23
- The artificial horizont is displayed only when Stratux has GPS fix.
- You can calibrate AHRS by long pressing the slip indicator at the bottom of the screen.
- If you want to see some information, tap the aircaft symbol.
Re: ADS-B
Postby Tonio » 09 Jun 2019, 10:18
What you get for less than US$ 300.-
FIF and Stratux AHRS-2019-05-12 22.11.54.jpg (121.13 KiB) Viewed 34117 times
FIF and Stratux ADSB_20190510_141614_gps.jpg (129.2 KiB) Viewed 34117 times
Re: ADS-B
Postby kabong.steve » 27 May 2021, 01:40
Whats the chance of getting support for this and all the compatible receivers?
https://flightaware.com/adsb/prostick/
Source code available here
https://github.com/flightaware/adsb-fli ... er-android
Less than $60Aud with antenna
kabong.steve
Re: ADS-B
Postby RogerF » 27 May 2021, 08:09
I am currently testing an Android application called "SAFESKY".
It requires an active 3G/4G connexion to the server to get the positions of nearby aircraft equipped with ADS-B, Flarm, or Safesky and provides a kind of TCAS display. The use of 3G/4G means that it will probably not work at high altitudes, but the aim is to cover GND-4500ft.
There is a pay (premium) version, but also a free version that provides all the basic functions.
It is free for obvious reasons: more users mean a better coverage of the traffic.
Currently, split screen is needed to see both SAFETSKY and FlyIsFun together.
However, the authors plan to allow for an integration with GPS softwares.
Not sure this will be free, however.
Re: ADS-B
Postby kabong.steve » 04 Jun 2021, 04:35
In theory, all that is really needed is to be able to use a local ip address and port.
Using the RTL-SDR driver (https://play.google.com/store/apps/deta ... _tcp_andro) you'd simply connect to locahost 127.0.0.1 and port 14423.
If only you didn't need the Wifi to connect to, or supported localhost, then we may get it running quicker.
great cheap addon for everyones safety
kabong.steve
Re: ADS-B
Postby kabong.steve » 24 Apr 2022, 02:32
Just to let everyone know I purchased a uAvionicx Skyecho 2 device for my plane.
Currently in Australia, you can apply for a 50% rebate from the government to go towards such a purchase.
https://uavionix.store/general-aviation ... /skyecho-2
This works perfectly with Fly Is Fun and shows we all I need to know.
This device also includes a TS0-C199 certified GPS and a barometric Altitude sensor.
FiF says it'll accept the GPS input thru GDL90, and I'm wondering if this solves the issue of background GPS usage for FiF.
Would also be good if FIF accepted the baro altitude values as well, so can include in instruments for the tablet I have without baro sensr.
kabong.steve
