RS232 NMEA výstup
RS232 NMEA výstup
Postby vikino » 01 Feb 2021, 13:21
Ahoj,
není náhodou v plánu NMEA výstup přes BT převodník aby z něho uměl brát data autopilot? Např. TruTrak a pak by z toho šlo to, co už jsem chtěl kdysi, posílat frekvence do vysílačky...
Vítek
vikino
Re: RS232 NMEA výstup
Postby Mano » 03 Feb 2021, 10:06
za posielanie freqvencie do vysielaciek ako ma aj xcsoar, alebo LK8000 by som sa priklanal...
Mano
Postby vikino » 04 Feb 2021, 21:38
I krmeni AP z FiF by byla pecka, Skydemon se k tomu nema, treba pristroje od FlyBoxu maji svoji meziaplikacku a tlaci to po wifi do AP...
Me by stacilo NMEA RS232 :)
vikino
Postby hgrdrro » 05 Feb 2021, 09:13
I also would very appreciate if FIF would be able to send NMEA data (GPS, Course, etc.) to an Autopilot via Bluetooth RS-232 converter.
This would be another beautifull improvement of FIF.
hgrdrro
Postby vikino » 05 Feb 2021, 11:07
OK, we will switch to English...
AP required informations and sentences are: $GPRMC, $GPRMB, $GPGGA, and $GPBOD or $GPAPB.
Output specs found here: http://aprs.gids.nl/nmea/
By Garmin described here: https://www8.garmin.com/manuals/webhelp ... 8DD93.html
BT to RS232 converter should be enough this one: http://www.usconverters.com/rs232-seria ... rt-adapter
This would be TOP over SkyDemon which does not support this
And i would definitelly suggest to use BT over WiFi, as FiF supports virtual radar, weather, it will get offline from cellular data on devices with data SIM card inside, when connected to WiFi-RS232
vikino
Postby RogerF » 18 Feb 2021, 14:09
I have just tested a free Android application called GPS2Bluetooth, coupling my smartphone GPS to my windows PC via bluetooth.
I think that it does what you are looking for.
The GPS position was useable on the PC (tested using Navigation/FouFou).
I also tested with another free app: GPS over BT
There is also a more complete app: "BlueTooth BPS", but only a 10' demo is free.
Postby vikino » 19 Apr 2021, 08:52
RogerF wrote:I have just tested a free Android application called GPS2Bluetooth, coupling my smartphone GPS to my windows PC via bluetooth.
is should be controlling AP, so only GPS position does not resolve problem, it would be nice to set on FiF NAV point or whole route and activate AP controlled by NMEA sentences from FiF.
I have found that Flybox Oblo has got launcher which lauches SkyDemon app and it is getting AP informations from Skydemon and they are able to control AP in Oblo...
This what im mentioning will be universal output from FiF via BT which gives posibility to connect it to older Dynon EFISes with AP, TruTrak AP....
vikino
Postby kitercuda » 02 May 2023, 18:04
I am thinking to implement NMEA output. Would anybody use it?
Postby vikino » 09 Jun 2023, 09:47
For controlling autopilot definitelly yes, and many peoples around me...
Usage of bluetooth-rs232 converter which we will use for radio co trolling will be great
vikino
Postby Vasut » 28 Aug 2023, 19:11
Také by se mi líbilo ovládat rádio přes NMEA... Zároveň bych využil přenos GPS dat do odpovídače.
Vasut
