New sotware until the end of April
Microsoft Flight Simulator X to Android
Re: New sotware until the end of April
Postby urbanchina » 02 Sep 2015, 17:26
Hi, I am not able to install server zip file, having same error as bigdatapimp. It would be nice to get my paid version of the app to work with fsx/P3D, so I can practice airspace awareness in conjunction to the real world.
urbanchina
Postby jprous » 15 Sep 2015, 10:32
Is it possible to do the same with FlightGear?
Love your app - I don't fly without it anymore!
Regards,
Jean-Pierre
RSA
jprous
Postby Developer » 15 Sep 2015, 10:52
My pleasure to feel your satisfaction. :) I am sorry, but we do not plan to modify applicaton for FlightGear for the present. Maybe later.
Developer
Postby rastojankovic » 07 Nov 2015, 12:20
I have still this problem.
rastojankovic
Postby AquilaBernd » 16 Nov 2015, 14:50
Hi Development Team,
I use FiF regular for trips with my small Aquila :-) It's really a great pice of Software. :)
Now my Question: will I'm be able to install the server component also in a Prepare 3D environment rather then FSX for my simulation needs? :?:
(P3D: This is the designated successor for FSX and has in big parts the same code basis)
Thank you in advance
Bernd
AquilaBernd
Postby Piotr66 » 05 Jan 2016, 08:19
Some times ago I bought You application called FSX2Android.
It worked very fine for my until today. I think, that it's somehow connected to the update 1.1 from day 28.12.2015. The application was running on my 10" tablet o'Lofer JustTab C1041IPS, after "some tricks". But now I can't upgrade to new version -> Google Play says that it's not compatible with my device and my old "tricks" don't work anymore (I have "This is unauthorized version"). Since now I was using FSX2Android to "feed" SkyDemon application, but today I also installed trial version of Yours FLY is FUN, but without FSX2Android working -> I can't try it.
Could You be so nice and help me with that?
Ps. Sorry for my poor English...
Piotr66
Postby micke » 07 Feb 2016, 17:37
I also have same problem running fsx2android server on Win10 with Prepar3d.
Is it incompatible?
Capture fsx2android.PNG (18.05 KiB) Viewed 13595 times
micke
Postby micke » 08 Feb 2016, 23:42
Server side solved.
By reinstalling the SimConnect.msi from location Program Files (x86)\Lockheed Martin\Prepar3D v3\redist\Interface\FSX-RTM\retail\lib
I'm now able to start the FSX2Android.exe server. (Seemed like the GAC wasn't registered correctly, GAC MAnager).
In the server window right side it says "Server is ready, waiting for client".
I now receive the correct GPS positions from Prepar3d in the server FSX2Android app.
Now I instead have problems with the Android app on my Sony Xperia Z2.
After allowing GPS MOCK Locations, giving the correct server IP and Port I hit "Connect" button, the Icon turns green directly.
Refresh count is always =0 and Info says "Connecting to server".
Shouldn't the client be visible here in the server app?
If I start FlyisFun or other apps reading GPS only the Phone position location is shown, not the Prepar3d position visible in the FSX2Android server.
How can I debug the Android FSX2Android App?
Br,
/Micke
micke
Postby danfic » 18 May 2016, 18:48
I get the same error message of bigdatapimp (see above).
I have Win 7 64 bit, .NET Framework 2, 3.5 and 4.6 installed and MS FSX Steam Edition: may be the problem is with the last one?
Thanks in advance for your help.
Daniele.
UPDATE: solved. Same solution as micke.
danfic
Postby yair1956 » 07 May 2017, 23:14
It is May of 2017
Just downloaded the server (Win10-Pro) to my reg, trying to run the installer and it crashing from the same reason.
Any ideas ???
Tnx in advance
Yair
Irvine CA
When you any GPS apps, can I use something like the AVARE ??
yair1956
Return to FSX to Android
