Postby kitercuda » 02 Sep 2014, 05:48
Coordinates have a lo ot digits. I will thinsk about it.
At this time: Menu / Tools and info / Position information
Postby Onuff » 08 Sep 2014, 11:29
X
Postby kitercuda » 12 Sep 2014, 16:17
It will be...
Postby kitercuda » 17 Sep 2014, 10:21
Now I was playing with your route without WPT labels.
I was caused, because the route was created using some WPTs in the database. In this case these WPTs are not displayed at the map, because of duplicity.
Original WPTs from database was deleted.
Postby Onuff » 17 Sep 2014, 20:40
Yes.you best.
How to keep a route one separately?
Postby kitercuda » 18 Sep 2014, 05:51
Every WPT route has information about the source:
1. Database
2. External (when you import for example GPX)
3. Map tap WPTs
If WPT has information, that it is from database it FIF do not display it - because it is already displayed.
Route WPT are saved in GIR files. It is just case of import. Maybe when importing FIF will make the checking if the WPTs exists in database. If not information about source will be rewrited from Database source to External source.
Edit: I implemented it, next upgrade...
Postby Onuff » 03 Dec 2014, 20:22
Hi Petr
Very much energy consumption excites app.
-if to switch off some screens
-minminimum brightness.
-to switch-off sensors and parameters.
+earlier for 1 hour of 15%
--for 2 hour of 40%
Postby kitercuda » 04 Dec 2014, 16:16
Yes you are right. I am happy I can recharge my device on board my Extra.
It is possible to set FIF for lower energy consumption at the Preferences, but you have to know what to set. I am planning to make it easy, one click for low power consumption, on click for best performance.
Postby flyyyer » 04 Dec 2014, 23:41
FYI It took me ages to find some 12v usb chargers/power units that put more power in when mobile than goes out when using any screen on app (like FIF). They do exist though. I can keep my Motorola Xoom 100% now and my Note 3 running for as long as needed...... The Battery on its own though is good enough except for long days/journeys.
The Note 3 is my backup and the virtual Radar transmitter , the 8 inch Xoom II is master nav. Both are very reliable.
Postby Onuff » 10 Feb 2015, 10:41
10%=1 hour
new aircraft
IL-76 big 1.jpg (2.08 KiB) Viewed 8133 times
