Quick Access to User Waypoints
Postby neusat » 25 Jul 2014, 19:15
Thanks for the great app!
I would like to suggest the possibility to add a button in "direct to navigation" item selection list , to go directly to user waypoint folder.
Sometimes is tedious when you are loading a route and have to mix user waypoints and word databases defined points.
Suppose your last airport was selected from /world database/argentina/airports/sazn, and you want to navigate to a user waypoint in /MyWpt (ouyside world database), it is necessary to press four times ".." and then enter to "MyWpt" to select the new nav point.
Would be really useful if in the menu you add a button like "User Wpt", and selection list goes directly to /MyWpt (would be a fixed folder or a folder or one defined in settings)
The same thing would be useful for quick access to World Database Airports, Navaids and WPTs for an specific country, defined as default.
Best Regards.
neusat
Re: Quick Access to User Waypoints
Postby kitercuda » 26 Jul 2014, 19:31
neusat wrote:Suppose your last airport was selected from /world database/argentina/airports/sazn, and you want to navigate to a user waypoint in /MyWpt (ouyside world database), it is necessary to press four times ".." and then enter to "MyWpt" to select the new nav point.
Not 4 times, just one LONG press [..] button :-)
Anyway try long press Find or Nearest button at the Nav item list.
Maybe this will solve your suggestion.
