Text size
Text size
Postby francojb » 18 Nov 2013, 13:56
Hi Petr!!! How are you??
After an update sometime ago, text size in Navigate items menus got too big and it is not fitting on the screen...
Is there a way to let them smaller again??
Thanks a lot for your answer!!!
francojb
Re: Text size
Postby kitercuda » 18 Nov 2013, 15:27
Please, post here screenshot.
Re: Text size
Postby francojb » 18 Nov 2013, 18:12
At wpt description text use to be smaller, the item name and filled in blank space, too, and both check boxes at localizer use to be visible...
And in Nav item list, buttons and text use to be smaller, too...
Small size text check box at screen settings is checked...
It is not very important, so if it is easy to fix ok, if it is not, it doesn t matter...
Thank you!!
francojb
