Import Elevation data - Bad header
Postby kitercuda » 12 Apr 2012, 18:27
When importing elevation data, application write Bad header.
This is correct header of .asc file (values ncols and nrows must be 6000)
ncols 6000
nrows 6000
xllcorner -85
yllcorner 25
cellsize 0.00083333333333333
NODATA_value -9999
Solution:
When downloading terrain data, setup download page like it is described on attached picture.
http://srtm.csi.cgiar.org/SELECTION/inputCoord.asp
Re: Import Elevation data - Bad header
Postby dirdiebirdie » 13 Apr 2012, 03:24
Ive downloaded some elevation data but i cant figure out how to import them into an android galaxy II.
dirdiebirdie
Postby kitercuda » 13 Apr 2012, 04:45
When you downloaded desired elevaton data from http://srtm.csi.cgiar.org/SELECTION/inputCoord.asp there are in .zip file (it looks like srtm_19_05.zip).
Unzip the file and you will see .asc file (it looks like srtm_19_05.asc).
Copy .asc file(s) to mobile SD card and start GPS_ILS_VOR application.
Press Menu / Tools / Import elevation data and tap on desired file(s) which you want to import.
You can import more areas to the application. You are limited only by size of your SD card.
Postby barneo66 » 15 Dec 2013, 04:45
Добрый день
Не могу разобраться как загружать рельеф выше 60 широты?????
На устройстве не хочет(((
barneo66
Postby barneo66 » 15 Dec 2013, 04:47
good day
I can not understand how to load relief above latitude 60?????
The device does not want to (((
barneo66
Postby kitercuda » 15 Dec 2013, 21:51
Post here terrain coordinates, which you need.
Postby barneo66 » 16 Dec 2013, 00:40
good day
70-68N
86-93E
barneo66
Postby kitercuda » 16 Dec 2013, 15:22
Sorry,
I have uploaded new data two month ago, but I forget to remove test (old data were from S60 till N60)
Next upgrade (this week) will solve it.
I checked your coordinates - data for you will be OK :-)
Postby barneo66 » 19 Dec 2013, 00:37
All OK!
Thank you very much!!
barneo66
Postby barneo66 » 19 Dec 2013, 01:49
Hi!
You can specify the address for downloading the relief above 60N.
Big Thanks
barneo66
