Bug reports and some suggestions
Postby Peuqui » 19 Apr 2023, 03:48
Hello Petr,
I found your App some weeks ago in the Playstore and began loving it very much!
Despite that I found some issues, they relativates its use for me quite a bit:
  • I would like to see all aviation related airfields in germany, not only the ED...
    • means: private airfields, UL-airfields and sailplane airfields
      those are not availabe at the moment
    • you may have a look at Apps like Enroute, which is for free or VFRNav, or AviaMaps
      - all of them displays the needed Airfields
  • Do you check your forum regularly? -> I posted some comments without reply yet...
  • Export of the Flightplan as "Flugdurchführungsplan_vfr.xls" contains lots of errors.
    • I am a programmer too and maybe being capable of correcting those errors in the xls-file.
    • Can you explain where this template is filled with data and how? Or do you fix it yourself?
  • Splitscreen isn't usable:
    • the app isn't able to recover the correct screen size when tried to use in split screen.
      Android 10 and 13 here in use.
    • my workaround is:
      • swiping to a different view (e.g. instruments), then I am able to enter preferences and then leaving preferences -> FlyIsFun is able to adapt to the correct screen size
  • Display GDL-90 data:
    • It would be nice, if bearingless targets won't displayed as surrounding airplanes
      instead, for better readability, it should displayed as a circle, like in VFRNav
    • (nearby) targets should be displayed with their height number above/under me and a short line indicating their directions
    • in the preferences should be a menu to set the displayed targets/aircraft +/- my actual height/altitude
      e.g. display only aircrafts, that are +/- 3000 ft above AND under me
    • btw: I am using a Stratux device for Traffic Collision Avoidance
Thank you very much for your enormous effort making this app so great!
Kind regards,
Markus
Peuqui
Re: Bug reports and some suggestions
Postby kitercuda » 02 May 2023, 18:25
Thanks, I will have a look at the nav database source.
