Draw over other apps and background ops
Postby kabong.steve » 24 Jan 2022, 00:20
I've noticed with the latest Android versions that the background running doesn't work anymore and we loose GPS when switched away.
I use another app called GPS Status, and when its closed or switches away, it appears in a window overlayed over other apps. you can move it around or close it, but it keeps running and updating its window.
Perhaps this would be possible with Fly is Fun and resolve the background issues.
Giving Fly is Fun the same functionality would be awesome. Allowing us to switch apps (or on tablets run other apps concurrently) and not loose the logging or GPS link when making phone calls or other such.
kabong.steve
Re: Draw over other apps and background ops
Postby kitercuda » 02 May 2023, 17:51
Application was updated several months ago. Now it can work with GPS at the background.
If it is not switched-on open Prefernces, click at the Internal sensor settings / Using GPS at the background.
If you have previously declined this, you need to set it up in Android Settings - Apps / FLY is FUN / Permissions / Position
