GDL90 extending to other devices
Postby xaxero » 02 Jul 2019, 00:13
As a long time user of your app - thank you - got me out of a jam many times.
I see you have Stratux integration - Excellent - now with some tweaking you could get iLevil integration - It is basically GDL90 with an IP 169.254.1.1 and UDP port 43211.
I am planing a long flight across South America and will be replacing the Stratux with a iLevil Astrolink as the AHRS is much better and I intend to use it as a standby gyro. My under the hood trials with Stratux showed significant deviation from the Vacuum gyros with extended manouvering.
This post details how to hack Stratux to work with software that only reads iLevil and so the coding required is minimal
https://www.reddit.com/r/stratux/commen ... ation_pro/
By adding iLevil support your app will gain even more exposure.
All the best
Jonathan
xaxero
Re: GDL90 extending to other devices
Postby kitercuda » 08 Jul 2019, 17:48
Thanks I will have a look.
Postby xaxero » 12 Jul 2019, 14:49
Thanks for the consideration.
I am happy to test an APK build for you so you do not have to purchase any hardware.
All the best
Jonathan
xaxero
