Calculate ETA
Calculate ETA
Postby muhali83 » 11 Dec 2016, 21:57
hi . great app really help full
app can calculate ETA when air craft is moving
can u add a feature to calculate ETA on gr , of all way points by putting Fix Take off time and Fix speed
example
input:
take off time 1215 hrs (UTC/LT)
Speed 100 NM,
route: Point A : 100NM , Point B : 50 NM
Output
ETA : Point A: 1315 hrs ,Point: B 1345 hrs etc ....
its great aid for planning on ground
muhali83
Postby Tonio » 11 Dec 2016, 22:34
To calculate on the ground ETA of a planned (but not yet activated route), being in the route library (where you see all route names) you should make a long press on the route name.
A pop up menu appear, there you can select "summary"
If a aircraft is selected, it will automatically calculate ETA for the route.
Users browsing this forum: Bing [Bot] and 1 guest
