Sharing Way Points - ULM airfields — airstrip ….
Postby Tonio » 15 Sep 2015, 17:13
What would think about having the ability of sharing WP or ULM air fields within FIF
a - Between our own Android handset
b - With othet FIF users
My idea will be
1 - When creating a point, user could get the following questions
“Would you like sharing the point with FIF community”? YES - NO
“Would you like sharing the point your other FIF devices? YES – NO
If the answer if YES, he will get the message
“Points created will be sent to FIF database, next time you will be connected to FIF server and then made available during the next 24 hours”
2 - next day next synchronization , from FIF to the user or to FIF commubity
only once a day, to avoid synchronization problems than could occur with to short delay and to allow FIF consolidation.
Every FIFI user should be able to create and modified user points
but FIF authority / editor should be able blocking the one that doesn't have acceptable behavior
Ex : creating wrong WP or destroying other WP, generating complaints…
Every FIF identified user should be able to become contributor?
What would think about that?
Have safe flights
Antoine
