Editing the active route in flight
Postby antonaks » 12 Feb 2015, 20:33
thanks for your program I of updating. Whether navigation can add function of editing an active route without stopping? I explain in more detail. In flight along the set route I need to turn off aside on object. Now I have to stop navigation, come into the menu and choose my route for editing. Further to choose the card and pressing on the screen to add a point. It would be desirable to add in flight by pressing a site of an active route to it a new turning point. Also this rotary can be taken aside on the card. For example on the lake, a bend of the river or on other object on the card. It is convenient when flying by rules of visual flight for helicopters. Very often in the flight to have to change a route and to add to it new rotary points. It will be convenient to make it directly from the screen by long pressing a site of a route and shifting it in the right place. Also it would be convenient to see distance and a course of flight at the stage of a route. These functions are in the air nav pro ios program. Your program indisputable more conveniently and better. If there is an opportunity, add these functions. Thanks.
antonaks
Re: Editing the active route in flight
Postby kitercuda » 15 Feb 2015, 15:29
Look here, chapter routes. You can easy navigate to non-route point and then restore route navigation.
http://funair.cz/domains/funair.cz/forum/viewtopic.php?f=11&t=5709
Postby onuffrienk » 01 Apr 2015, 11:30
Peter , hello , I use your program , very satisfied ) ))))
The idea of ​​editing the route during the flight route is very good. For example selecting a point on the map might be possible "Add to Route " not to go into the menu , routes, build on the map ....... It would be nice if you would think about this question )))
onuffrienk
Postby kitercuda » 04 Apr 2015, 05:40
I think about Add to Route button at the pop-up info box (there are NAV2, VHF etc)
Postby onuffrienk » 01 Jul 2015, 03:36
Thank you))))))))))
onuffrienk
Users browsing this forum: No registered users and 12 guests
