Event Logger
Event Logger
Postby Vegas » 26 Dec 2014, 01:07
This could be useful to remember the number of landings and approaches that you did.
So the idea is to create 3 buttons (that you can edit the label) and every time that you tap the button it Logs the name of the event and the GPS time.
It can create a document if you have "event Logger" enabled with the events that you tapped.
I will use it for something else but the idea is the same! :)
Any day above ground is a good day!
Vegas
Re: Event Logger
Postby kitercuda » 27 Dec 2014, 16:26
I think you can use FIF logbook...
