add turn coordinator
PostPosted: 12 Jun 2014, 14:36
by cristiangb
Hello, I pass you an idea to add the coordinator turns, the idea is, like the plane, a 360° in 2 minutes. I attached a picture I took of a GPS (Rate of Turn).
Thanks.
Hola, yo te paso una idea para agregar el coordinador de giros, la idea es, al igual que el avión, un giro de 360° en 2 minutos. te adjunto una foto que saqué de un GPS (Rate of Turn).
Gracias.
Re: add turn coordinator
PostPosted: 14 Jun 2014, 13:30
Hi, I am planning to do it...
PostPosted: 16 Jul 2014, 14:41
by cristiangb
Hello, good job with turns coordinator, the only problem I saw is when you near ground, the red or orange color in the "terrain map" (Samsung S3 on vertical position) view does not distinguish, I send you a screenshot. Anyway at that altitude is not to look inside the instruments .... :lol: :D
Cristián.
PostPosted: 18 Jul 2014, 07:58
by pjp
Maybe put around (up to) compass ? And not only on terrain screen, but on map screen too ?
But - in CZ glider training system (still ?) exist course "flight in the sky" (mandatory for FI qualification in past, actually I don't know) and because in case L-13 was horizont only as options and not so many CZ aeroclub have/had got (really some have it ?), this training was based only on turn & slip indicator (standart instalation) and both, somehow, in FiF actually exist ... but it's true, how "calibrate" right position of handy or tablet for slip indicator ... ? ;-)
Pavel
PostPosted: 18 Jul 2014, 13:40
by cristiangb
Sorry but my English is not so good, and the gogle translator did not improve the situation in this case.
What is "CZ" and "FI"? I understand that the L-13 is Blanik glider.
Regarding if the map screen does, is no problem because the map background is almost white, then red and orange highlights well.
Anyway, it is only in the vertical position of S3, in the horizontal position the background is gray and is well distinguished, as the map of land is set aside.
That screenshot I made at ground level, and as I said: "Anyway at that altitude is not to look inside the instruments ...."
PostPosted: 18 Jul 2014, 17:09
by pjp
CZ - Czech Republic
FI - Flight Instructor, in this case GLD FI (instructor for gliders).
I checked old book from Svazarm time (V-PL-4 to -6, basic book for glider pilot & training in Czechoslovakia socialist republic) and I didn't find any description of this training and I don't know, if it's somewhere describe ...
Pavel
