VOR Radial
VOR Radial
Postby Laotse » 03 Dec 2013, 10:29
Dear Pitr,
I am using FiF as a "backup" solution in the cockpit. It is just GREAT!
We are doing the normal flight routing procedures with onboard systems, but as we usually have to report to our ATC at certain distances from a specific VOR/DME system I have the following question:
You have the very nice feature of "POSITION INFORMATION", where e.g. I can see my BEARING (VOR TO value) etc. Our ATC usually wants to hear on which radial (VOR FROM) we currently are. So then I have to calculate the opposite vector of the BEARING value. That is no big deal, but sometimes one is just very busy in the cockpit, so reading it immediately would be great.
Would it be possible to make the RADIAL value directly available? Maybe even chooseable in the general screen boxes?
Kind regards,
Laotse
Laotse
Re: VOR Radial
Postby kitercuda » 04 Dec 2013, 06:25
Yes, i will do it.
Re: VOR Radial
Postby Laotse » 04 Dec 2013, 07:48
Wow, great. You should think about a "Donate" button in your app. ;-)
Happy landings,
Laotse
Laotse
Re: VOR Radial
Postby kitercuda » 05 Dec 2013, 20:24
Yes I should do it :-D
Anyvay, if you long tap at the map - you will see BRG to taped pos, radial from taped pos, distance and elevation...
Re: VOR Radial
Postby Laotse » 11 Dec 2013, 07:34
Petr, thank you very much for the feature!
Laotse
Re: VOR Radial
Postby cristiangb » 04 Mar 2014, 14:28
Hi!, great idea, I think about this option when see the Nearest list -actualy can see Name, Distance and a small arrow indicating the direction of the point-.
On that list is a good place to make it look the radial.
Cristián
cristiangb
Re: VOR Radial
Postby kitercuda » 07 Mar 2014, 06:42
Maybe in landscape mode...
