FTD, MGS, ACV, values to logbook
Postby flyyyer » 17 Dec 2014, 15:25
On the wish list... can you store the Flight track distance, max ground speed and accelerometer values into the look book entry? I have a couple of these active but always forget to look before closing down FIF .
Thanks for the vertical view on map screen ver 16.60
Regards Peter G
G-BYLS
Re: FTD, MGS, ACV, values to logbook
Postby kitercuda » 18 Dec 2014, 13:14
It is saved (from version 16.54). In logs, created versions before 16.54, it is possible to calculate it because FIF saves flight track (just display it)
Groud speed - also saved, so max GS is just about display it
G-meter - it was wasted time of implementing it. I do not know why, Android sensors give only maximum 2g in one axis. So if your plane make 4g load factor, you can see only 2g. I have read a lot about it. Sensors in our devices can send more to 10g in one axis, but there is an restriction for us - 2g max.
Postby flyyyer » 18 Dec 2014, 13:23
Great Stuff, Thanks Petr. Yes shame about the G-Meter, would be good for you I expect....I hope you have a strong mount in your plane :-)
Postby kitercuda » 18 Dec 2014, 13:45
Look at its, I need nore than 10g ;)
Postby flyyyer » 18 Dec 2014, 13:53
I watched your videos some time ago with you taking your "friends" a ride. All smiling ......at the begining. I was going to cadge a ride if I was in the area.... not at that G !
If anyone hasn't seen Petrs videos , have a look.... very amusing.
Users browsing this forum: No registered users and 16 guests
