Version 26
Version 26
Postby kitercuda » 10 Feb 2020, 05:21
Version 26.60
- TAFs displayed at the map. Color scheme is the same like METARs.
- Switch-on TAFs at the map: At map screen long press the compass rose for screen customize and find button METAR / TAF...
- At the screen customizing you can also replace one of the screen values by selecting MTS - METAR / TAF switcher. There is a loop when you tap it (OFF, METAR, TAF +!, TAF +2...). The number means forecast time now + 1 hour, now + 2 hours, etc.
- If you long tap MTS, it quickly switch-off the METAR/TAF displying at the map
Version 26.53
- Removed bugs
Version 26.51
- If there is wind gusts, wind speed text color is red (METAR list, TAF)
- If METAR contains wind direction which vary, it is displayed at METAR list with red color, for example: 180 - 260.
- Changed color scheme GAFOR - yellow color was splitted into two yellow colors. DIFF has minimum ceiling 1000 ft, DIFF+ has mimimum ceiling 2000 ft.
Version 26.50
- If it is displayed RRA (Rainfall Radar Age) at the map screen, you can tap it for on/off displaying rainfall radar at the map. For displaying RRA use the Screen customizing.
- METARs are displayed at the map. It is a circle with wind direction. Color of the circle is dependent of weather and selected color scheme. Color scheme is possible to set in Preferences or METAR list. The length of wind barb is dependent of wind.
- Switch on METARs at the map: At map screen long press the compass rose for screen customize and find button METAR / TAF...
- At the screen customizing you can also replace one of the screen values by selecting MTS - METAR / TAF switcher. Then you will see at the map screen if METARs are on/off and tap it for on/off.
- Update Spanish and Slovenian language version, thanks to Rolando and Jernej.
Version 26.43
- Updated Czech, German, French, Italian, Poland and Russian version. Thanks to Juergen, Antoine, Marco, Krzystof and Alex.
Version 26.42
- METAR and TAF weather is decoded. At this time English only. Translations will follow.
- You can select displaying sky coverage using icon or text (FEW, SCT, BKN...). At METAR list press Menu / Color scheme
- TAF has also color scheme (the same as METAR).
- Removed small bugs.
Version 26.30
- Displayed METAR color scheme at METAR list
- Refactored METAR list in landscape mode
- Refactored TAF in landscape mode
- A lot of small changes at TAF and METAR list
- Updated German French and Italian version. Thanks to Juergen, Antoine and Marco.
Version 26.20
- Added possibility for sorting METARs by distance or ICAO code. Look at the METAR optons menu.
- Added 4 color scheme for visibility and cloud ceiling (FAA, GAFOR, NATO, ORBIFLY). Look at METAR optons menu.
- Updated Polish and Czech version. Thanks to Krzystof
Version 26.11
- Decoded Wind shear, Turbulence, Icing (TAF)
- Removing some bugs
Version 26.10
- Displayed decoded TAF (Tap at the METAR at METAR list)
- Added menu for METAR list and TAF window.
- Possible use UTC or LT for METARs and TAFs decoded data
Version 26.00
- Totaly refactored METAR internal engine to SQL based one. It is prepared for displaying METARs at the map.
- For NOTAM history tap the NOTAM at NOTAM list
- Some icons are refactored
- Added option for route METAR download: Do not download FIR NOTAMs
