Version 23.10
- Added VORTAC and TACAN to database - Database update necessary
- Easy displaying airspace from menu: Airspace list. Long tap at the airspace, select Show at the map centre
Version 23.01
- Added support for wind. You can display wind and measure wind during the flight. If application knows wind, it is diplayed at the map screen. Menu / In flight settings / Wind or customize screen select value WD or WS and then if you tap it, you get the wind menu.
- Updated French, German, Italian, Polish and Spanish version. Thanks to Antoine, Juergen, Marco, Krzystof and Rolando.
