Version 13.00-17.63
Version 13.00-17.63
Postby kitercuda » 02 Feb 2014, 15:34
Version 17.63
- Application now requires at least Android version 4.0.3. - Ice Cream Sandwich
- Application hide software Android navigation bar if it is not necessary. If you want to see it, Preferences / Screen settings / Full screen mode
- Removed bug: application always displayed DME to the end of route with default distance unit.
Version 17.62
- Refactored file import/export dialog. Better look in landscape mode, possible delete file (long tap)
- Possible export route in GPX format.
- Possible export Nav database in GPX format.
Version 17.61
- Improved downloading topo maps - possible to delete maps, displayed user maps
- Auto settings the baro sensor (if it is present)
- Updated Russia and Spanish version. Thanks to Aleck amd Rolando.
Version 17.60
- Added ET (estimated time) for NAV2
- Added possibility to use SD card without root for Android 4.4 - 6.0 (at your own risk). Preferences / Data management / Data location
- Improved downloading topo maps, added a lot of US maps - Thanks to Antoine
- Added possibility for using external data sources
- Updated Spanish version. Thanks to Rolando.
- Updated Czech, Italian, French, German and Poland. Thanks to Marco, Antoine, Juergen, and Krzysztof.
Version 17.50
- Changed colors at the next WPT window
- Added yelow BRG to NAV2 line
- Better lines look, possible to set bigger width
- Logbook displays average ground speed
- Updated Czech, Italian, French, German and Russia and Poland version. Thanks to Marco, Antoine Juergen, Aleck and Krzysztof.
Version 17.41
- Improved landscape mode of Logbook list, Terrain data manager and Import the world nav database.
Version 17.40
- Refactored elevation data download. Better landscape view, added button for choosing area at the map. Menu/Downloads/Terrain data manager. Then press Map button. At the map you can select/deselect area by long tapping.
Version 17.33
- Added new European maps - Thanks to Antoine.
- Possible to hide CRS (green) line at the map. Customize screen / Press button CRS color.
- Removed bug: ETA and ET and Fuel at the information box (after map object tapping) displayed bad value.
Version 17.32
- Removed bug: In reverse portrrait and reverese landscape screen format application made roll. This is removed.
- Possible set map lines width (CRS, Route, etc.). Customize screneen...
Version 17.31
- Added MGRS coordinate format. If you fill latitude by MGRS coordinate, longitude will be ignored. Or you can switch coordinates format to MGRS in the Preferences. Then application displays MGRS (no lat/lon).
Version 17.21
- Database changes (more possibilities of kind of RWYs and APTs)
Version 17.20
- Improved units selection. Metric x Imperial was replaced by Speed unit, Distance unit, Altitude unit and Vertical speed unit.
- Switch off NAV1 (Menu / Navigate / Stop NAV1)
- Updated Czech, Italian, Spanish, French, German and Russia and Poland version. Thanks to Marco, Rolando, Antoine Juergen, Aleck and Krzysztof.
Version 17.10
- In the map object information dialog added NAV1 button.
- You can start route creating by tapping map object and then tapping the Route button.
- After long tap item at route list or nav database list you can tap Select all
- Updated Czech, Italian, Spanish, French and Poland version. Thanks to Marco, Rolando, Antoine and Krzysztof.
Version 17.01
- Sending coordinates to another applications. Long tap WPT at the Nav database / Show in another application
- Updated Russia and Italy version. Thanks to Aleck and Marco.
- Possible sending WPTs or Routes in GPX format.
- Removed some bugs
Version 17.00
- Exporting sigle or selected routes possible. For multi select swipe routes from right to the left.
- Exporting sigle or selected nav items possible. For multi select swipe nav items from right to the left.
- You can send routes and nav items from na database via email attachements. Select some route(s) or nav item(s) by swipping to the left, long click at them, and select Send.
- You can receive routes and nav items via email attachements. Just click at the email attachements and then select where you want to store it.
- Added Italian UL fields - You must download World nav database again, thanks to Marco
- Updated Czech, German, Spanish, French and Poland version. Thanks to Juergen, Rolando, Antoine and Krzysztof.
- Removed some minor bugs.
Version 16.93
- DME can be displayed with more precision, Preferences - Screen settings / High displayed DME precision
- Added description, how to control application: Menu/Downloads/How to use application
- Added URL and Description to airports - will be used in future for more information in FIF database.
- Added all European topographical map - Thanks to Antoine
Version 16.92
- Long press plus and minus zoom button displays zoom menu.
- Removed bug when displaying next WPT name. Sometimes was displayed ICAO code twice.
Version 16.91
- Changed the default screen settings
- Better visibility of the north symbol and the next WPT name window.
Version 16.90
- Application displays projected flight track. If you want to hide it, customize screen (long tap the compass rose) and uncheck Display projected flight track.
Version 16.88
- Added airliner aircraft symbol (Preferences - Screen settings / Aircraft symbol / Airliner
- Removed bug when displayed some coordinates
Version 16.87
- Updated Spanish, Russian and German version. Thanks to Rolando, Aleck and Juergen
- Removed bug with displaying RMZ - radio mandatory zone (it requires import worlds nav database again)
Version 16.86
- Data management (Menu/app settings/Preferences - General settings / Data management). Possible reindexing database and deleting data.
- When you long click at the logbook row and then select Show at the map centre you will see the start position at the map centre.
- Updated French, Italian, Polish and Czech version. Thanks to Antoine, Marco and Krzysztof.
Version 16.85
- Possible display DME unit independent of the main Metric/imperial settings (Customize screen)
- Better visivility of Rate of Turn indicator at map screens and compass rose scale
- When you long tap map without GPS signal, application displays coordinates and elevation of tapped position.
Version 16.84
- Added RDL for NAV2 (Customize screen)
- German UL and glider airports have now main RWY direction information (needed reimport the world nav database)
- Removed bug - exporting preferences (settings) was impossible
Version 16.83
- If you tap something active at the main screen, tapped place change color
Version 16.82
- Updated user guide (Menu/Downloads/User guide)
- Updated Spanish. Thanks Rolando.
- Optimalized default map settings
Version 16.81
- Possible customize CRS and HDB value windows (Customize screen...)
- Updates German and Russian version. Thanks to Juergen and Aleck
Version 16.80
- Data location dialog moved to the Preferences / General settings / Data location and it is user friendly now.
- Possible to use external SD card at Android 4.4. For more information visit http://www.funair.cz/forum / General information and download / FAQ
- Preferences / Screen settings / Screen orientation - added possibility Reverse landscape
- Updated French, Polish, Italian and Czech version. Thanks to Antoine, Marco and Krzysztof.
Version 16.70
- All screens, whose have menu, have menu button now (at the top/right). If you want to access menu from the main screen, short tap compass rose (it was before CRS settings). CRS settings is still available by tapping CRS value window.
Version 16.66
- Possible set map orientation to CRS up. You must allow it in the Preferences (Screen settings / map orientation). Then you can switch among North Up, Track up and CRS up by long tapping the north symbol.
- Removed bug - Some airspaces with unlimited top border were not displaying. You have to import airpspaces again to see then (Menu / Import and download / World nav database)
Version 16.65
- If there are diaplyed on the screen end of route ETE, ETA or DME and route is not activated, application displays values to the next WPT
- Improved nearest dialog - long press at APT, WPT, TWPT or RWY check box opens dialog, where you can choose more.
- Removed bug.
Version 16.64
- When active route is opened, after long tap at the WPT it is possible to display it at the centre of the map
- Removed bugs
Version 16.63
- Added more WPT and TWPT types. I recomend update world nav database.
- Customize screen - long press at APT, WPT or TWPT check box opens dialog, where you can choose more.
Version 16.62
- When you edit a route and you first time press Map edit the last WPT will be displayed at the center of the map.
- When you edit a route, you can easy display WPT at the map center (Edit route, long press WPT and select Show at the map center)
- Removed bugs
Version 16.61
- When you open logbook row, you can see max ground speed and flight track distance.
- Removed some bugs
Version 16.60
- Added vertical view to the map screen (you can move map by fingers and watch the changes at the vertical view)
- Added button Direct to at the (CRS) course set dialog (tap at the CRS value)
- Switching NAV1 and NAV2. Now 3 possibilities what to do with CRS. Preferences / Screen settings / Switching NAV1 and NAV2.
- Updated Russian, German, Spanish, French, Italian, Polish and Czech version. Thanks to Aleck, Juergen, Rolando, Antoine, Marco and Krzysztof.
Version 16.56
- Improved vertical view
- Added grid with labels
- Added displaying NAV1, NAV2
- Added displaying ILS Glide slope (ILS must be established)
- Changed NAV1 DME text color to blue (now NAV1 DME is blue, NAV2 DME is yellow)
Version 16.55
- Possible set any nav item from Nav item list to the centre of the map (Open Nav item list, long tap item, To map centre)
- Thanks to Aleck for updating Russian version
- Removed some bugs
Version 16.54
- Application now records flight track distance too. You can see it when you open the logbook or if you customize screen and you select FTD.
- When application loss and then recover GPS signal, logbook can continue recording without creating the new row.
- Thanks to Marco, Rolando and Antoine for updating Italian, Spanish and French version
Version 16.53
- Settings FIF for VFR/IFR using by on click: Preferences / General settings / VFR/IFR settings (you can hide all IFR nav items at the Nav Item list and at the map)
- Nav item list: If you use history, nearest or text search you can long click at any item and select Open parent folder from the context menu.
- Thanks to Juergen and Krzysztof for updating Germna and Polish version
Version 16.52
- Better map long tap (if you long tap close to objects, object will be selected)
- Possible NAV2 when long tap map
- Removed some bugs
Version 16.51
- Updated Italian, Polish and German version. Thanks to Marco, Krzysztof, Juergen.
- Added RMZ (radio mandatory zone) airspace type
- Customizing airspaces and patterns colors and transparency (Customize sreen/Airspaces and pattern colors)
Version 16.50
- Refactored route map creating (long tap, rubber band...). Thanks to Juergen for tuning...
- Updated German, Czech and Russia version. Thanks to Juergen and Alexander
Version 16.42
- Possible switch-off rotating map by two fingers (Preferences, Screen settings/Tapping settings)
- Updated Russian version. Thanks to Alexander
- Removed bug when map editing the route in landscape mode
Version 16.41
- Possible set height of vertical view (Customize screen)
- Refactored flight simulator dialog box
Version 16.40
- When user moves map by finger and then do not tap map again, application lock map after selected time.
- Possible to turn map by two fingers.
- If user moves map by finger and the aircraft symbol is not visible, application displays arrow to its.
- Updated French and Spanish version. Thanks to Antoine and Rolando
Version 16.31
- Preferences: Airspace settings moved to Screen settings
- Possible set upper limit for displaying the airspaces when you are not airborne or you are editing your route (Preferences: Screen settings/Altitude settings/Altitude to hide)
- Displaying the temperature (you must allow the temperature sensor then customize screen)
- Displaying the relative humidity (you must allow the humidity sensor then customize screen)
- Displaying the density altitude (you must allow the temperature, pressure and humidity sensor in preferences then you must customize screen for displaying density altitude - DAL)
- Density altitude calculator (Menu/Tools and info/Density altitude calc or tap DAL value)
- User friendly pressure sensor calibrating (Preferences/Sensor settings/Pressure sensor calibrating). You device must have pressure sensor.
- Upodated French, Italian, Polish, German and Russian version. Thanks to Antoine, Marco, Krzysztof, Juergen and Alexander.
Version 16.23
- Created quick start video guide (Menu/Downloads/Video guide)
- Added French version - Thanks to Antoine
- Fixed some bugs
Version 16.22
- When route map editing, application shows all airspaces.
- Updated Spanish version - Thanks to Rolando
- Fixed some bugs
Version 16.21
- Finished translation of Spanish version - Thanks to Rolando
- Updated German version - Thanks to Juergen
- Possible mute Marker Beacons (Preferences / Marker Beacons)
- Fixed some bugs
Version 16.20
- Added airspaces to the vertical situation window
- Updated Polish version - Thanks to Krzysztof
- Finished translation of Italian version - Thanks to Marco
Version 16.01
- Removed bugs
Version 16.00
- Finished translation of Polish version - Thanks to Krzysztof
- Terrain view has vertical situation window - beta version, airspaces will be displayed soon. If you do not want it, costomize screen and uncheck Display vertical view
- Removed bug when airspace warning. Sometimes was not visible VHF button.
Version 15.93
- Better zooming by 2 fingers
- Removed bug - when tap airspace at terrain screen, some airspaces were not hightlighted.
Version 15.92
- If accelerometer value is out of range (unfortunatelly the accelerometer's range of the most of Android devices is 2g in one axis) text color is orange.
- Finished translation of German version - Thanks to Juergen
- Updated Russian version - Thanks to Alexander
Version 15.91
- Possible set screen size if dialog boxes and font are too big or too small (Menu / App settings / Preferences - Screen settings)
- Finshed translation to Czech language
- Fixed some bugs
Version 15.90
- Refactored all dialog boxes for lot of screen sizes
- Update German version - Thanks to Juergen
- Update Russian version - Thanks to Alexander
- Added Polish version - Thanks to Krzysztof
- Translated Czech dialog boxes
Version 15.81
- Application displays RWY names, starting at zoom 2nm (4km). It is possible to customize it (long tap compass rose for opening screen customize dialog)
- Improved Spanish version - many thanks to Rolando
- Improved German version - many thanks to Juergen
- Improved Russian version - many thanks to Alexander
- Finished first stage of Italian version - many thanks to Marco
Version 15.80
- Possible changing VFR patterns color (Customize screen by long tapping compass rose)
- Background brightness set (Prefeences / Screen settings / Background brightness)
- Frames brightness set (Prefeences / Screen settings / Frames brightness)
- Refactored Preferences
- Started creating multi language version, beta version. If you do not like it open Preferences / Genersl settings / Language and select English.
- Sometimes was impossible to download maps and database. I hope it is fixed :-)
Version 15.72
- Search edit text boxes have X-button for deleting all content.
- If you set reminder at the route WPT or Alarm clock - reminder has yellow text color.
Version 15.71
- Better map object touch response (reduced falses when aicraft is shaking)
- Prev/Next and restore route navigation buttons on the map (long press them open the route dialog box). You must allow them if you want to use them (Preferences / Screen settings / Map buttons)
- Customizing screen - added airspaces (you can for example hide airspaces class E, F, G)
Version 15.70
- When importing the World database, possible to check/uncheck heliports importing (Menu/Import and download/The World nav database)
- Map screen can have 3 value rows at the portrait mode (Display topo map screen, customize screen and check Display 3 value rows)
Version 15.62
- If the sensor status is unreliable, you can ignore it and use it (Preferences / Sensor settings)
- All lines (CRS, BRG, Route, Track, Holding patters) can be hided or set transparency (Customize screen, press color button).
- Possible to set CTR fill transparency and color (Customize screen, press color button).
- Added Romania topo map
Version 15.61
- If new World nav database is available, application warns you (Switch-on(off) this feature Preferences - Other settings)
- Nav item list - arrows to items can be related to north or to current track (Preferences - Screen settings / Direction arrow north up)
- Updated Italy VFR report points - Thanks to Marco
- added Italian user guide (Menu/Import and download/User guide) - Thanks to Marco
Version 15.60
- Added Accelerometer (Long tap compass rose for customize screen and select ACM - Accelerometer). Short tapping at the value rectangle displays max value, long tapping reset max value
- Improving topographical map import. You can long tap at the map name in the list and then select Show URL.
- Updated European obstacles
Version 15.50
- Rate of turn indicator (you can easy check 2 minutes 360turn). Rate of turn is possible to switch off at the Preferences/Sensor settings.
- Map zoom - swipe map up or down
Version 15.40
- better displaying CTRs (filled like at the ICAO maps)
- Updated database (Hungarian small airports, airspaces, ...) - Thanks to Olivier and Zoltan
- Added Spain user guide - Thanks to Rolando (Menu/Import and download/User guide)
- Added TRA and TSA airspace type
Version 15.32
- Application restarts when user enables or disables sensors in Preferences.
- When importing/exporting screen orientation is frozen
- Long tap slip indicator - calibrate it
- Added ELEV to tap pop-up info box
- Edit route (or active route) dialog box. ICAO code is displayed if necessary (RWY, VRP, etc.)
- Added French user guide (Menu/Import and download/User guide). Many thanks to Michel...
- Obstacles icons are a little bit bigger
- Removed bug: Topo map sometimes does not redraw when source was changed.
Version 15.31
- Removed some bugs
- Updated database (1406), especially Poland and Australia VRPs, Poland airspaces
Version 15.30
- Route navigation pause: When route navigation is active and you do - direct to, route navigation is not calcelled, but paused only. For restoring the route nav open route dialog and tap desired route WPT or tap at WPT name info box (near TRK) and select Restore route navigation.
- When route map editting you can add route WPT by short tap map object and then long tap info dialog box (like map tap direct to)
- When exporting track from logbook using KML format you can decide which format do you preferer: Preferences / Logbook / KML export track format.
- METAR list - when favorite METAR does not exist, it is displayed with N/A text
Version 15.20
- Export / import pilots, aircrafts and logbook (internal format)
- When application warn before entering the airspace, airspace is highlighted (yellow color - like tapping it)
- Easy terrain map look setup: FLY is FUN x Garmin. Tap AGL value window or Open Preferences / Terrain map settings / Load default values
- Backup, restore and restore Preferences moved from Menu/App settings to Preferences.
- Fixed some bugs
Version 15.10
- Terrain map - Garmin style possible:
- Open Preferences / Terrain map settings
- Green Height - 300 ft
- Red Height - 100 ft
- Show all obstacles - unchecked
- Safe height AGL color - Black
- Shade terrain map color - unchecked
- Logbook select all rows - Long tap any item, tap Select all at context menu.
- If you set Alarm clock (tap LT or UTC walu window) or DME alert (tap DME) application show triangle bugs.
- Removed bug - sometimes was impossible to tap airspace border for displaying information about tapped airspace
Version 15.00
- External Bluetooth GPS support (Menu/App settings/Preferences - Sensor settings)
Version 14.65
- Improved map object info box - added NAV2 and PDF buttons.
- VHF decimal point can be . or , (Menu/App settings/Preferences Unit select/VHF decimal point)
- Added helicopter symbol (Menu/App settings/Preferences Screen settings/Aircraft symbol)
- Importing the World nav database improved - added Menu/Select previously imported countries
Version 14.64
- Better information dialog box (up to two buttons). Tap an object on the map and you will see information box. If an object has VHF, it will have VHF button. The second button with object name is designed for quick opening the object folder (for example if you tap APT you will see all APT RWYs).
- Added maps: Bulgaria, Brasil, New Zealand
Version 14.63
- New aircraft symbol (you can select old one - Menu/App settings/Preferences/Screen settings/Aircraft symbol
- Removed bug - Sometimes GPS signal loss warning dialog box did not dissapear when GPS signal was OK again.
- Removed bug - When you tap some WPT at the map, you see info dialog box. Long tap dialog box - direct to WPT. Time for long tap was too short.
Version 14.62
- New searching possibility (Nav item list and Adding route WPT). Possible to enter text;ICAO. For example "RWY 03;EDFH" find RWY 03 at EDFH or "RWY;ED" find all items which name or notes contain string RWY and ICAO contains ED (Germany). For more information see updated user guide.
- Adding route WPT via command line.
Version 14.61
- Route edit dialog box: Possible to see PDFs and all VHFs of WPT, if this information are available. Long tap desired WPT and then select from context menu VHF or PDF.
- Removed PlaneFinder from Virtual radar - now it will work again :-)
Version 14.60
- When next WPT is changed, background of window with next WPT name changes color to dark yellow for 4 seconds.
- Logbook summary calculates power and glider time/landings separately
- Added World topographical map (Menu/Import and download/Topographical map)
- Updated Czech VHFs
- Updated Slovak ATZs
- Updated Germany VFR airport patterns (Thanks to Juergen)
- Removed bug - Importing GPX routes: If the route in GPX file has no name, application will create it.
Version 14.54
- More time to enter possibilities at airspace warnings settings (up to 6min): Preferences/Warnings and Info Box/Airspaces/Time to Enter
- Removed bug: some soft surface RWYs was displayed gray. Now there are green.
- Removed bug: At LogBook was impossible to select date from(to) twice.
Version 14.53
- When calculating logbook summary and found some error, application stops calculating and notify user.
- Importing preferences do not import the data path, if path not exists (important when synchroniying more devices).
- Updatew the World database, cycle 1404
- Added TMZ - Transpoder Mandatory Zone (Germany)
- Added Swiss VFR airport patterns (thanks to Juergen)
Version 14.52
- New design of pop-up information (tap map object)
- Long tap settings (vibrate and beep) - Preferences Screen settings/Tapping settings
Version 14.51
- Alarm clock. Tap LT or UTC value window...
- Airspaces alert improved: Approaching from top, bottom - better alarm message and customizable at Preferences: Warnings / Airspaces / Vertical distance
- Enables to save to the aircraft list non standard callsigns and designators. Added Czech ultralight callsign pattern (OK-AAA 01).
Version 14.50
- Airspace warnings - application warns before entering the controlled or special use airspaces. Look at the Prefernces - Warnings / Airspaces. There are a lot of settings.
- Removed some bugs
Version 14.44
- Screen orientation lock is back with one more options :-)
- Added warnings settings to the Preferences
Version 14.43
- New route WPT switching notification
- New GPS signal loss notification
- Removed bug - When the last WPT of the route was RWY or LOC, CRS was set to bad direction.
- Updated the World nav database
Version 14.42
- Logbook KML export tracks format changed
- DME NAV1 and NAV2 alert: Tap NAV1 DME or NAV2 DME value window and set distance. When DME cross this value, application genertes alert. For removing the alerts long tap DME value window.
Version 14.41
- Added possibility of activate using promo code
- Improved database structure
Version 14.40
- Virtual radar - application displays planes from Planefinder - thanks to Vladimir
- Long tap at ACC (GPS accuracy) switch on/off virtual radar. The flashing dot inside of ACC window is green (on) or red (off).
- Customize screen impoved - possible customizing ATZs, Traffic patterns (Germany, Austria), virtual radar plane labels
- Selecting terrain files to download is easier - you can determine center point (it can be given by GPS) and radius and application calculates which files to download.
- Updated Germany airport patterns
- Added Austria airport patterns - thanks to Juergen
Version 14.31
- Added BRG NAV2 and DME NAV2 values. If you want to see them, customize screem (long tap compass rose).
- Removed bug - displayed BRG rounding
- Removed some other bugs, which could cause application crash
Version 14.30
- Changed trial licence. One month of unlimted version, no another limitation.
- When you tap map object without GPS signal, you will see its coordinates and ELEV.
- World database updated - added small Brazilian airports
Version 14.20
- Multitouch - zoom out and zoom in at the topo map screen by two fingers. This action cause that map switch to "shift by finger" (not by GPS position). If you want to switch back, tap at the north symbol or long press ZOOM+ or ZOOM- buttons.
- Switching screen by swiping is possible also when map is in "finger shift mode". Just sStart swiping outside of the map...
- Customizable aircraft symbol vertical position (While customizing map screen and drag Aircraft symbol pos seek bar)
- Sending logbook row(s) to email (headers or tracks). Open logbook, select rows (swipe them to the left), long tap any item, select Export (send) from context menu...
- Possible disabling logbook notifying (when it starts or finishes automatic recording) - Preferences/Logbook.
- Removed bug: local time DTA could display bad value.
- Removed bug: after tapping map objects pop-up info box sometimes did not appear.
Version 14.10
- Switching NAV1 and NAV2 - Long tap WPT name at the main screen.
- Airport patterns if available are displayed only from zoom 0.25nm till 10nm.
Version 14.03
- Removed bug: Virtual radar could crash sometimes.
Version 14.02
- Application uses less memory and map loading is faster.
- World database was updated to 1402
Version 14.01
- Added 5 seconds refresh interval for virtual radar
- Updated user guide, have a look at chapter 11 - Virtual radar.
- Removed bug: Virtual radar aircraft displayed bad GS
- Removed bug: When application had no signal and user zoom fast several times at topo the map, application sometimes did not redraw.
Version 14.00
- Virtual radar (beta version). Before switching on open Logbook (Menu / Tools and info / Logbook then open Aircraft list and create an aircraft. After aircraft is created, long tap at it and from context menu select: set in use. For switching on open Preferences / Virtual radar.
Version 13.72
- Removed bug: bad ET, ETA in the pop-up info box (after tapping object on the map) when imperial units are selected in the preferences.
Version 13.71
- Map info box units are depended of the ground strip and altitude strip unit settings (Menu/App settings/Preferences Unit select/Speed/Strips and info box ALT unit and Strips and info box GS unit)
- Improved average algorithm
Version 13.70
- Better slip indicator movement
- HDG (heading bug) renamed to HDB
- Added HDG value - compass heading
- If ground speed is less than defined value, application uses compass heading and GPS track is set to undefined value. Menu/App settings/Preferences/Sensor settings/Min GS for GPS track
- Reorganized preferences - added Sensor category
Version 13.60
- Slip indicator settings: Preferences/Screen settings/Slip indicator
- Slip indicator calibrate: long tap at the aircraft symbol at the centre of compass rose or Menu/App settings/Calibrate
- Added Preferences/Altitude and Vario/Rounding VSI values
- VSI can change color if is bigger(green) or lower(red) than adjusted threshold value - Preference/Altitude and Vario/Threshold for color VSI value
- Added settings Preferences/Screen settings/Render when dirty only
Version 13.51
- World nav Database updated
- User guide updated
- Long tap SW1 SW2 - reset stop watch
- Pop-up information box again improved (after tapping airspace or map object):
1. Tap it - close it
2. Long tap it - Navigate to it
Version 13.50
- New launcher icon
- Nav2 has tail arrow at the compass rose
- ETE to the next WPT was changed from ETE to ET
- Changed About dialog - added recent changes button
- Route Edit and Active Route dialog display more information in landscape mode
- Improved nav item touching information:
1. RWY, ILS and LOC items displays length and width of rwy
2. If default aircraft is set and its cruise fuel flow is adjusted, FIF displays fuel consumption
3. Highlighting time customize (Menu/App settings/Preferences/Screen settings/Highlighting).
Version 13.40
- Merry Christmas and happy New Year!!!
- After tapping nav items at the map application displays info (like a tapping airspace border). You can customize it Menu/App Settings/Preferences/Screen settings/Highlighting
- Elevation data available from S85 till N85
- Updated Slovakia airports (included RWYs). Thanks to Honza from Slovakia
Version 13.33
- Terrain data available from latitude 80S till 80N.
- Updated and optimized USA datatabase. Import is more quickly.
Version 13.32
- Updated airspaces database
- Australia small airports added to database, thanks to Vladimir
- Better selecting Topographical map source (sorted and removed .sqlitedb)
- Nav item list: RWY items show RWY threshold elevation
Version 13.31
- Added RDL - Radial value type (Long tap compass rose for Customize screen, the select RDL)
- Removed bug: When application switched route WPT, name of new wpt was redrawn only at active screen
- Removed bug: country codes of: Montserrat TR, Trinidad and Tobago TT, U.K Virgin islands TU
Version 13.30
- Updated all database, import world nav database
- Added Australian VFR WPTs - Many thanks to Vladimir from Australia for his help
- Added WPT types
Version 13.20
- Hiding unused screens - If you do not use some screen you can hide it in preferences. When switching screens by swipping the hided screen will not be used (Menu/App settings/Preferences, Screen settings/Show/hide screen)
- Airspace list renamed to Airspaces and Patterns. This list can contain now not only airspaces, but patterns too
- Added German VFR airport patterns to database, thanks a lot to Juergen for his help. If you need them, Menu/Import and download/World Nav Database and import Germany again.
- European obstacles added to database (Menu/Import and download/The World Nav Database)
- Route list or active route dialog after tapping: End of route ETA, Distance to the end of route, End of route ETE
- MGS max ground speed is possible to reset by long tap its value
- Tapping AGL opens AGL colors dialog
Version 13.11
- Updated User guide
- Added DTA value - desired time of arrival overhead next WPT - for more information read new user guide chapter 11.6
- Tapping DTA - Adjusting desired time of arrival
- Tapping QNH value - QNH set dialog
- Tapping GS value - Speed bug set dialog
- Tapping ALT value - Altitude bug set dialog
Version 13.10
- Route planning - Added altitude, desired time over WPT, reminder. For more information download new user guide, chapter 6
- Better Heading/Altitude/Speed bug dialog box
- Heading/Altitude/Speed bugs are saved when application finish and restore when launch
- Altitde bug is now displayed also in altitude values rectangles. For more information download new user guide, chapter 11.5
Version 13.00
- Calculator of max terrain strip elevation (include obstacles) - Menu / Tools and Info / Max terrain elev calculator. Application calculates max elevation of user defind (orthodrome) strip defined by 2 WPTs. You can select also width and overlap of the strip. Elevation data must be downloaded (Menu / Import and download/Terrain data manager). European users - do not forget to downaload obstacles database (flyisfun.com, section Navigation database).
- Updated user giude
GPS_ILS_VOR_GlassCockpit.apk
(4.17 MiB) Downloaded 627 times
