- Navigation to second WPT. Open Nav item list thne long press desired item and select Navigate 2. At the compass rose you will see yellow triangle - Bearing to the second WPT. For stopping navigation to second WPT press Menu / Navigate / Stop nav 2
- Removed Auto Logbook altitude bug: Application saved gps raw altitude. Now application save either correct GPS altitude (geoid corrected) or barometric altitude (long tap at altitude strip and select)
