Version 7.20
Version 7.20
Postby kitercuda » 12 Nov 2012, 18:24
- Long click at the nav item and then select Sunrise, sunset calculator...
- Flight simulator - simulator flight control. You can easy simulate flight Menu/Tools and Info/Flight simulator
- When you select non approach nav item (all except ILS, RWY, LOC) course will be set to this item.
- Application is more accurate now: Replaced Android formulas for counting initial bearing and distance between 2 WPTs by my own
