sdcard
sdcard
Postby rondum » 21 Jun 2014, 12:19
I want to transfer my data in my sdcard, because on my tablet I miss space,,,, in - app setting - data folder---I enter the path of my sdcard manually---/sdcard / GPS_ILS_VOR---
When I reboot FLYISFUN by default the software return on my tablet, i try to tranfert manuelly data on my sdcard, but nothing work
is go all the time on my tablet, someone is abble to help me,
my tablet is samsung galaxy tab4
android 4.4.2
tank's in advance
Ron
rondum
Re: sdcard
Postby beks » 25 Jun 2014, 07:41
If I'm not wrong your problem is that you can't load maps from sd card if that is the problem (I had similar problem) you have to root your tablet and install "nextapp sdfix" (you can download it from google play it's free) reboot and set your data path to sd card location. It's android 4.4. limitation, and not the app problem.
hope it helps
beks
Re: sdcard
Postby zdenekh » 06 Jan 2015, 08:47
Yes, it's 4.4.2 android limitation, but no need root. Directory GPS_ILS_VOR Just copy on external card to the path \ Android \ data \ gps.ils.vor.glasscockpit \ files \ GPS_ILS_VOR, there's a law application for reading and writing. gps.ils.vor.glasscockpit is the system name of the application, you must create this directory. The navigation system then works without any problems.
zdenekh
Re: sdcard
Postby kitercuda » 10 Jan 2015, 09:54
Thanks for hint, I will try it.
Re: sdcard
Postby kitercuda » 12 Jan 2015, 06:24
It is working ;)
I tried it by creating only \ Android \ data \ gps.ils.vor.glasscockpit
Re: sdcard
Postby Toreh62 » 24 Oct 2015, 09:48
It's not working for me. I also have a Samsung tab with 4.4.2. I have tried all folder combinations that suggested in the manual and in this forum. On my phone however, it works fine. (Samsung s4 with android 5.0.1)
Toreh62
