Nav database
Re: Nav database
Postby kitercuda » 04 Jan 2014, 09:07
There is possible to change all data in FIF...
If you have some VRP list of your region (Where is your region?) it is quite easy to import it.
Re: Nav database
Postby helikamov » 04 Jan 2014, 14:06
Yes sir, I can import it but mine will be over the stored inside the app. and on screen will be two points at one and same place, with two different symbols and names.
That's why I prefer to export the build in points, to change only their names (that's the problem) and to import them back with the right names.
I mean LB region. For LBBG there are missing in the app. and for LBPD and for LBSF their names are not correct.
10x
helikamov
Re: Nav database
Postby helikamov » 04 Jan 2014, 14:08
Excuse me again,
Would you explain to me haw can I change build in nav data?
10x
helikamov
Re: Nav database
Postby Onuff » 04 Jan 2014, 17:00
Can divide the basis and the user bases somehow?
I have points too other than standard base
(when updating base remote points will appear)
Re: Nav database
Postby kitercuda » 06 Jan 2014, 18:53
Can you send me file, with right names?
Re: Nav database
Postby helikamov » 07 Jan 2014, 12:16
I will m8, but after 4 hour
Good luck!
helikamov
Re: Nav database
Postby helikamov » 15 Jan 2014, 16:24
I solved the problem like this:
- not downloading VRP Data for my country
- import the points from GPX file
- change their icons in FIF
that's all
Good luck m8s
helikamov
Re: Nav database
Postby no-bat » 15 Jan 2014, 16:58
2helikamov
Do you have MVL points of all Russia?
Re: Nav database
Postby helikamov » 15 Jan 2014, 17:12
I Have all Garmin nav data base,
but What is MVL point
helikamov
Re: Nav database
Postby no-bat » 15 Jan 2014, 18:43
Could you download your nav data base to the forum?))
