by Eliseo » 29 Nov 2019, 17:27
Thank you very much for answering
I know the operation of the FiF quite well.
Look at the photos, input when under the data I do not select the heliports and these if they go down, then we select them in "Screen costumizing" as well as the ultralight and if they appear on the screen.
I remind you that in general the aerodromes that do not start with LE in Spain are Ultralight and it seems that they can not separate from the airports this issue we already touched on years ago and possibly I did not understand enough, I hope to fix it now, because it really is a Important problem.
Thank you very much.
- Attachments
- Screenshot_20191129-180631.png (254.89 KiB) Viewed 20974 times
- Screenshot_20191129-175039.png (242.3 KiB) Viewed 20974 times
