Skyvector HI,LO,VFR (maps)
Skyvector HI,LO,VFR (maps) 1704
Postby giventofly » 14 Apr 2017, 18:03
Hello. in attachment you find skyvector map files for SAS.Planet. I tested it. Working fine ;) Data efficiency: 1704
Code: Select all
https://uloz.to/!l76xDXURMfXa/skyvector-1704-zip
Psswd: 123456789
Enjoy...
giventofly
Re: Skyvector HI,LO,VFR (maps)
Postby Onuff » 11 May 2017, 20:48
Postby sweiss » 18 Aug 2017, 08:13
Thanks very much for the zip file!
Can you post the URL for the tile server?
I am guessing it is something along the lines of:
https://t.skyvector.com/1704/301/{z}/{x}/{y}.jpg ?
cheers
sweiss
Postby giventofly » 20 Oct 2017, 15:31
sweiss wrote:Hi,
cheers
https://t.skyvector.com/mnmnmbdbdbbd/302/1711/
giventofly
Postby giventofly » 26 Oct 2017, 10:31
SkyVector Map for FlyIsFun 2017/11 LOW IFR . Coverage: Europe, Asia, North Africa.
https://uloz.to/!N6eXNTtGIBoS/lowifr-jpg
Download here:
Code: Select all
https://uloz.to/!zkniBZQ72Z8F/low-ifr-skyvector-1711-rar
giventofly
Postby Onuff » 08 Nov 2017, 20:14
New map
Skyvector HiLo 1711
2in1
Новый вид карты надо заценить!!!!!!!!
????????С начало идет Hi потом Lo
При первой загрузке надо подождать пока обработаются тайлы.
https://yadi.sk/d/QM7vxn043PTj7t
Postby vacaap » 08 Mar 2018, 20:42
Hi can anyone post new skyvector maps for europe low IFR? thanks in advance
vacaap
Postby Onuff » 21 Dec 2018, 16:26
Postby ctapoeys » 13 Aug 2019, 12:41
Hi everybody. I'm trying to make SkyVector maps for Brazil but it's not working. Coul'd someone give me a hand?
ctapoeys
