Aircrafts failure
Aircrafts failure
Postby Frank » 05 Mar 2020, 23:20
After importing aircrats the list is still empty and after creating a new aircraft an error message is popping up "Fehler beim Schreiben in Databasis". That means error while writing in database.
All other imports did work perfectly.
Samsung Galaxy Note 10 +
Frank
Frank
Re: Aircrafts failure
Postby kitercuda » 07 Mar 2020, 17:29
Can you post here (zipped) your which you imported?
There is a file .../Database/logbook.db. This file contains aircrafts, pilots and logbook. Try to rename it for example to logbook.db1. Application will create new empty one.
Postby Frank » 08 Mar 2020, 17:34
Renaming was successful. Thanks for your quick reply.
Frank
