KML Files Time Shift
Postby Frank » 02 Jul 2019, 20:45
After exporting to KLM the displayed time is shifted wrong (2 hours to much) .
For GPX all things are in the right position.
Frank
Re: KML Files Time Shift
Postby kitercuda » 08 Jul 2019, 17:40
What did you exactly export? There aer a lot of possibilities for exporting in FIF.
Postby Frank » 09 Jul 2019, 20:07
Inside the logbook I take one single flight - share - send - kml to send the kml file via email with the result discribed before.
Try it, watch carefully und you will see what happens.
Do the same with gpx instead of kml and you will see not a hair is out of place.
Frank
Postby kitercuda » 11 Jul 2019, 19:53
I will have a look, thanks.
