Replay logbook track
Postby Ricardo » 09 Jan 2019, 13:25
Hello, is there a way to replay a logbook track? if not, Can it be added, for exxample, to the simulator?
Ricardo
Re: Replay logbook track
Postby Tonio » 09 Jan 2019, 21:18
Hi Ricardo
I think its possible
Refer to FIF user guide chapter 13 and then 13.1.1
You will see it could be quite impressive especially when replying on 65” screen or projected on a wall
Have fun
Postby Ricardo » 10 Jan 2019, 11:04
Thank you for the answer. Yes, I've made the replay on GE but I was asking about replay the track inside FiF.
Ricardo
Postby Tonio » 11 Jan 2019, 04:29
There, I don't know. Never tried
I only use replay with GE ... until now.
Postby kitercuda » 23 Jan 2019, 20:14
Inside FIF it is not implemented.
Postby RogerF » 18 Feb 2019, 08:22
A possible way to replay a track is to use the Lockito GPS simulator.
You load a GPX file in Lockito and when it replays it, FlyIsFun sees it instead of the actual GPS.
There are some restrictions:
- Lockito does not replay the speed and the altitude recorded in the GPX file, but only positions, while altitude and speed can be specified as constant.
Despite this, this is a useful way to get acquainted with FlyIsFun, as a complement to the embedded simulator.
