Page 1 of 2
Changing standard flightlog
PostPosted: 12 Mar 2018, 15:33
by rotaxquax
hy guys,
there is a very nice German flightlog for using.
Is it possible to change your nice flightlog to
the German one?
Thx for any idea.
harry
Re: Changing standard flightlog
PostPosted: 21 Mar 2018, 06:55
Where I can find German flight log?
PostPosted: 26 Mar 2018, 10:02
by rotaxquax
thx for reply.
I cannot upload xls format.
PostPosted: 28 Mar 2018, 17:22
Compress it by zip.
PostPosted: 29 Mar 2018, 07:12
by rotaxquax
thx for response.
Voila the flightlog which is very common in Germany!.
Another similar flightlog is on the web fl95.de,
a nice flight preparation tool,
maybe good for any insperation to your Fif.
regards
harry
PostPosted: 29 Mar 2018, 20:43
by Tonio
It’s possible customizing the XLS log
Building your own customized log nav, you need to use data provided by FIF, that are saved the « raw data » tab.
Building your own customized log nav, make sure including the « raw data » tab in your file with its name and make sure to leave it unchanged
You can download default FIF xls log nav via this link http://www.funair.cz/downloads/template ... mplate.xls
To populate your own customized log nav, you will use data stored « raw data » tab.
Once you created your own log nav template will be customized/ according your needs, you need to store it in XLS format (not in XLXS) on your Android device
It should be stored in the “Route” folder located in “Templates” folder of FIF application
“GPS_ILS_VOR -> Templates -> Routes” (GPS_ILS_VOR folder is Fly Is Fun application folder)
Then to use your template, exporting the route, chose “send”, then “xls – Flight log”, then your template in “Template”
Enclose an example of customized template
LogNavFR 180331 V2.xls.zip
(95.64 KiB) Downloaded 841 times
Have fun
PS once your log will be ready, do not hesitate ti share it.
PostPosted: 03 Apr 2018, 13:34
by rotaxquax
hi all
first,
thx tonio for your nice description!
second
voila,
as Tonio suggested the first issue of the
German flight log for Fif.
I would appreciate any idea
for any eventually bug.
harry
PostPosted: 03 Apr 2018, 19:23
by Tonio
Hi Harry
Nice !!!!
and great
Hello every body
Could make some proposal and vote
Then we will ask Petr, if he can integrate / propose downloading the best
Enclose a V2 of my own log
LogNavFR 180402.xls.zip
(59.02 KiB) Downloaded 759 times
Not many changes, just lighter
Have nice flights
PostPosted: 05 Apr 2018, 21:31
by Tonio
Hi Harry
Petr, just created a "template" section in "general and download" section, where invite users sharing there templates
Could you move your template to this sections
PostPosted: 06 Apr 2018, 16:27
by rotaxquax
hi tonio,
WILCO :-)
regards harry
