Hello!
My SD card was failed few days ago.
But I moved files of FlyisFun to safe place, changed SD card and moved data back to new SD card. Everything was fine except of journal files. Journal became clear. All records like lost. But I found the old renamed corrupted file as logbook.db.corrupted. Is it possible to recovery information from this file? I tried to rename this file to logbook.db and start application. In this case application was shutting down after the trying to open journal.
Thank you.
