problem database Avioportolano Italy
Postby turillo1986 » 19 Jan 2018, 11:31
glad the "aviosuperfici" in Italy changed the code and now are standard and using the same as avioportolano, but we missed a BIG data on most airstrips, we don't have anymore the info on runway lenght. Before it was visibile by entering in the modify mode, now sometimes it is visible in the pop up like with airports, but in most cases (and sometimes also for airports) this data is not availble, which is a very big issue as I can't evaluate if that airport is good as an alternative for Landing or not as i don't know anything about the runway.
In avioportolano database you ahve info for all runways direction and lenght, can this be fixed?
thanks in advance.
turillo1986
Re: problem database Avioportolano Italy
Postby kitercuda » 27 Jan 2018, 19:11
Hi, we changed Italy data source to Avioportolano. I hope next AIRAC upgrade (1802) will solve a lot of missing data...
