Open flight map not actual
Postby sonntagc » 25 Jun 2017, 02:30
Hi.
The actual map of the open flight map project, all ready is shown the latest updates of the German airspace.
TMZ zones with squak and radio listening frequency
But in the download area is only a version from 10/2016
How to get an actual one?
Best regards Christian
sonntagc
Re: Open flight map not actual
Postby sonntagc » 25 Jun 2017, 08:35
Hi.
I send an email to open flight map org
And they can provide you with the newest map data.
It's only to intigrated in the download area.
This map is not only a map. It's also shows a lot of additional flight Infos.
And it quiet up to date to the official flight maps.
As long as the air structure is not completely integrated in flyisfun its help not to enter in existing TMZ zones etc.
Special the topic of TMZ with squak and radio listening frequency is solved.
If I can help to bring the German airspace up to date, give me an advice how to to it. Special, how to bring the additional frequency and squak Infos in a uniform way to the airspace.
sonntagc
Postby sonntagc » 25 Jun 2017, 13:45
Or can you explain me how to convert the by open flight map website provided formats so that I can intigrated them in the map directory
Christian
sonntagc
Postby kitercuda » 08 Jul 2017, 08:32
Have a look here:
viewtopic.php?f=4&t=5975
Postby rotaxquax » 26 Jul 2017, 14:21
Hi folks,
on openflightmaps.xxx there are newer OFM-map files!
in different formats. (Geotiff , mapbox format,epsg3857 tites).
Can FiF handle one of this formats?
How about aixm, openair,cup,arinc424 interfaces?
I am a bit confused with all that expression?!! :roll:
Is there someone who can explain a bit more?
Thanks a lot
Cheers harry
rotaxquax
Postby Tonio » 26 Jul 2017, 18:19
Try this
1 - Go to Open Flight Maps web site
https://openflightmaps.org/live/
2 - Select the region
3 - Chose “Get latest products”
4 – in “Application format”
Chose “EPSG3857 Tiles”
and then
“download”
5 – Once downloaded on the device, unzip the file
6 – Open Fly is Fun
7 - select “Downloads” ->then “Topographical Maps”
8 – In “Maps library” select “Import” -> then “Slippy Mercator/Zoom/Column”
9 – go to the files that need to be imported
then open the “unzipped file”
then in this folder open folder called “Original”
then in this folder open folder called “merged” *
then in this folder open folder called “256”
then in this folder open folder called “latest”
Here you are, you will see folders called “10” – “11” – “6” – “7” – “8” – “9”
Don’t open them
10 - Select the “Green arrow”
a windows is popping up showing zoom level that will be imported and inviting to enter a name
11 - Give a name
12 – Validate selecting the green arrow
Importation starts, after you know
* if instead of “merged” folder you select “base” folder you will get the map as background without “aero” data
very convenient within FIF
* if instead of “merged” folder you select “aero” folder you will get “aero” data without map in background
useless
Have fun and safe flights
Postby rotaxquax » 27 Jul 2017, 09:57
Hi Tonio
THX a lot for your instruction!!
Just another question regarding your
Point 9!
What do I have to extract?(..."need to import"..)
All files or the merged files or the Aero files vor the base files?
Please again, give me an idea what the difference is?
I hope it looks like these ofm(ICAO) maps!??
Thanks again for assistance.
Cheers harry
rotaxquax
Postby rotaxquax » 27 Jul 2017, 15:31
THX again. in the meantime
I could manage the questions by myself!
Merged directory with 512 resolution has a great cancellation
and costs 850MB storage
rotaxquax
Postby Tonio » 27 Jul 2017, 16:50
You will find enclosed a PDF user guide with screen copies
May be it will help you
ZIP files imported from Open Flight Maps site are huge
It could be faster doing it via a PC, unzipping the file and then transferring only required data on the Android handset
If you like download the Open Flight base Maps in RMAPS SQLITE here are some links.
Austria
https://www.dropbox.com/s/c0asv62aj1503 ... itedb?dl=0
Belgium
https://www.dropbox.com/s/nsdycilkcqj9x ... itedb?dl=0
Bulgaria
https://www.dropbox.com/s/62vnzbntcz81m ... itedb?dl=0
Denmark
https://www.dropbox.com/s/yt1ndkwe3axpb ... itedb?dl=0
Germany
https://www.dropbox.com/s/yuk02orkvqnnv ... itedb?dl=0
Hungary
https://www.dropbox.com/s/8domvgn20g6rl ... itedb?dl=0
Netherlands
https://www.dropbox.com/s/wfrsj98k0t1zl ... itedb?dl=0
Poland
https://www.dropbox.com/s/jwaorwjpcf59s ... itedb?dl=0
Romania
Slovenia
https://www.dropbox.com/s/5ewzffw4fnjkx ... itedb?dl=0
Switzerland
https://www.dropbox.com/s/3n3pbdvm4f9jj ... itedb?dl=0
I didn’t created maps with Aero data as Fly Is Fun is already providing aero data following AIRAC cycle…
Have save flights
Importing OpenFlight Maps into Fly is Fun Lite.pdf
(594.47 KiB) Downloaded 460 times
Postby rotaxquax » 27 Jul 2017, 21:31
Great assistance Tonio,
again
Thank you very much!
Harry
@kitercuda (stands for?.. :) )
A really great APP !!
Do you think, that you can manage
these adsb/anticollision issue in the closer
future?
Data received with dvbt dongles,
prepard with dump1090 and
get visible in your FiF...
I would pay another 30€ or something like
that....
rotaxquax
