Critical Terrain Map BUG?!
Postby germtangc » 21 Jan 2017, 03:40
I have noticed this "bug" in the terrain map page of the app recently. I have updated to version 19.23 and this bug may have already been present in earlier versions. This video sums it up:
I am using a Samsung Note 4 and previously have not experienced this problem.
ADD: I think there is a problem with the algorithm where it calculates AGL using the glideslope/climb angle of the aircraft as reference. So it seems that while descending, the far areas become purple because those areas are above the glideslope. Is this a BUG or a FEATURE?
germtangc
Re: Critical Terrain Map BUG?!
Postby no-bat » 21 Jan 2017, 12:42
New feature))
Postby germtangc » 21 Jan 2017, 14:52
Thanks for that. I might have missed the changelog.
After posting I was looking at the screen settings and there's an option to uncheck "use projected flight path for terrain colors".
That must be the toggle... Will try with FSX atm.
EDIT: Ok problem solved. It is a new feature. Helpful for PFL.
germtangc
