Convert .JPG Chart to .SQL
Postby Edwin » 22 Oct 2016, 14:14
Hi!
I have a JPG file, calibrated with OziExplorer (have a .MAP file associated).
But I dont´t knok to convert this JPG file to SLQ!!!!
Where can I find a tutorial about this?
Thank you in advance!!!!
Hola!
Tengo un archivo JPG que esta calibrado con el OziExplorer (tiene su archivo MAP asociado).
Pero no se como convertir ese archivo JPG a un SQL!!!!
Donde puedo encontrar un tutorial para hacerlo=
Desde ya Gracias!!!
Edwin
Corrientes - Argentina.
Edwin
Re: Convert .JPG Chart to .SQL
Postby Tonio » 23 Oct 2016, 13:38
Hi Edwin
I use generally:
MOBAC to create map, using online sources (maps)
and
Global Mappers (on windows) to convert maps
I have no idea if they can convert OziExplorer files
It seem that MAPC2MAPC could help you solving your problem
http://www.the-thorns.org.uk/mapping/help/uses.html
https://groups.google.com/forum/#!topic ... zcqdcqjNaE
Let us know
Have safe flights
Postby kitercuda » 26 Oct 2016, 09:46
There is one more possibility - importing Slippy mercator maps (tiles in folders). Menu / Downloads / Maps, Menu / Import...
