Minimum distance for route wpt
Postby Aerofun » 01 Sep 2016, 00:41
I need to scan an area with exactly paralel lines. When i create route, because paralel lines are below 0.5 km i`m not able to define and save route. How can I ( if posible ) alter value for minimum distance between waypoints ? Default is more than 500m, but i need to be 400m ...
Aerofun
Re: Minimum distance for route wpt
Postby kitercuda » 25 Sep 2016, 15:06
Hi, I will have a look if it is possible. There is an algorithm for switching WPTs. If possible, I can add vthis alue to the preferences.
Edit:
Next upgrade will have it...
