Topo map Downloads
Topo map Downloads
Postby Garyh » 26 Apr 2016, 01:11
Hi, is anyone out there having trouble downloading Topo Maps. My Samsung S5 Android 5.0 stops downloading with an Error just near the end.
Garyh
Re: Topo map Downloads
Postby Tonio » 27 Apr 2016, 15:47
Hi Garyth
Right now having Wifi and ADSL connection and/or 3G/4G connection it work perfectly with my Samsung Galaxy A3 running Android 5.0.1
If your data connection is to slow you (typical with 2G / Edge networks), data transmission could be a problem.
Did you try downloading the map with another terminal (ex PC)?
You can get the URL doing long press on the Map name in Map library
Have safe flights
Postby kitercuda » 28 Apr 2016, 08:12
Here you can find all available maps links:
http://www.funair.cz/downloads/maps/map2.info
Maps are located at your device here ...\Maps\RMapSQLite
