After playing around with setup, I switched off the touchscr
Postby rotaxquax » 06 Apr 2016, 07:48
Hi folks,
grrrr.....after playing around with setup I switched off my touch sensivity button, so
I cannot handle anything at all on the screen.. :o :? ....how can I switch it on again?
My problem is, when I use Fif at my kneepad, every casually touch on the screen
changes something....hmmm....!?
THX for any idea.
Quax
rotaxquax
Re: After playing around with setup, I switched off the touc
Postby rotaxquax » 06 Apr 2016, 14:24
I guess I have to manually manipulate the Fif config files!
Restoring my FiF 18.01 changed nothing... :?
No input is possible anymore!
Can anyone give me an idea, where the config-files in an Android system are situated?
rotaxquax
Postby kitercuda » 07 Apr 2016, 06:03
Hi, you mean you switch-off "Enable tapping" at the Preferences/Screen settings/Tapping settings?
This is very stupid option, sorry. I will delete it, because now it blocks everyrthing. I hope I wil publish the upgrade this weekend.
What you recomend, how you would like to lock and unlock screen during the flight?
Try:
Menu / App settings / Preferences
General settings / Factory default
If you have not root rights of your device, access to config files is denied.
Postby rotaxquax » 18 Apr 2016, 08:36
Thank you for reply kitercuda
In the meantime I made a Deinstallation... Installation.. :o :oops:
It works perfect again!
Sorry I have no recommendation against readjusting/blocking display after
accidentally touching the screen! :?
rotaxquax
