Export a single route
Postby Ricardo » 08 Jun 2015, 08:21
Hi, there is a way to export a single route in FiF? in the Route menu I can oly export all routes not only one.
Ricardo
Re: Export a single route
Postby kitercuda » 09 Jun 2015, 19:02
Not yet.
Next version will enable sharing routes and wpts via email.
Postby kitercuda » 10 Jun 2015, 08:26
Next upgrade will enable export or send single or selected routes...
Postby Ricardo » 12 Jun 2015, 18:21
Thank you so much
Ricardo
Postby Tonio » 19 Jun 2015, 00:09
Export of route work fine:
Long press on route to export
Select "send" to send it by mail
You can then chose FIF format or kml or GPS
Same for import you can import directly from your mail a GPX route that is attached
