CAN NOT IMPORT KMZ INTO SAMSUNG GALAXY TAB
Postby pablopoyaves » 14 May 2015, 21:45
hello guys, I followed every step of user guide... but can not import neither kmz or kml files, I did it successfully into my mobilphone (huawei honor 6), when I am trying to import into samsung galaxy tab it says.... import 0 files ... I hope somebody could help me, thanks in advance!!!!
pablopoyaves
Re: CAN NOT IMPORT KMZ INTO SAMSUNG GALAXY TAB
Postby kitercuda » 16 May 2015, 06:33
ZIP files and upload them, here.
Postby pablopoyaves » 18 May 2015, 12:06
kitercuda wrote:ZIP files and upload them, here.
hello again !!! thank you so much for your prompt answer, I have attached the file... as I said it is a kmz file, hope you can help me.
Best regards.
VaVadza.rar
(23.73 KiB) Downloaded 355 times
pablopoyaves
Postby kitercuda » 21 May 2015, 14:46
KMZ is zipped KML file. Your VaVadza.kmz file contains KML file, but inside folder (it should be in root.
There are 2 solutions:
1. Save file as KML
2. Rename VaVadza.kmz to VaVadza.zip, unzip file and import VaVadza.kml
Postby pablopoyaves » 27 May 2015, 13:59
Hi my friend!! Finally I unzipped the kml file as you told me and it worked perfectly!!! Thank you sooo much for your help!!!
Best regards!
pablopoyaves
