downloaded topo maps not showing - except world map
Postby maddav » 01 May 2015, 11:41
The application seems to work fine overall but it looks like when I download a new topographic map (e.g. for spain) it doesn't make a difference, I still see the world map I first downloaded and no more details. Also, it is pretty slow to drag the map (I am running it on a blackberry maybe it's slower than "real" android).
maddav
Re: downloaded topo maps not showing - except world map
Postby kitercuda » 02 May 2015, 11:45
Did you try:
1. Long tap map and then select "Topographical map source"
or
2. Menu (tap the compass rose) / App settings / Topographical map source
Postby maddav » 05 May 2015, 00:15
Thanks but I tried that already before asking...
maddav
Postby kitercuda » 05 May 2015, 20:31
I think run this application on Blackberry is not good idea. There are a lot of parallel threads which needs a lot of microprocessor time. If you run it on emulator, it can be very slowly,
Anyway - you can download maps manually. Long press at the map and then select Show soure URL and then copy it to GPS_ILS_VOR/Maps/RMapSQLite folder.
