Print FP
Print FP
Postby B21 » 08 Apr 2015, 20:16
Hello.
Is there any possibility to print the flightplan as you can see it on the route dialog box or in navigate/route/edit ?
Many Thanks
B21
Re: Print FP
Postby kitercuda » 09 Apr 2015, 11:00
Not yet. Flight plan will be refactored soon...
Re: Print FP
Postby B21 » 20 Apr 2015, 17:49
Sorry, of course I ment the the Flight Logs (not the Flight Plans)
At the moment I copy the route datas by writing them manually from FiF screen on a paper.
Best regardes
B21
Re: Print FP
Postby kitercuda » 21 Apr 2015, 11:38
Yes you can do it:
- Select which rows you want (swipe to the lef) to export (or send by email)
- Long press one of them
- Export/Send
- Choose Headers
Re: Print FP
Postby B21 » 21 Apr 2015, 14:41
Thanks for your answer.
But that don´t works. Perhaps the beginning of my procedure is wrong.
That´s what I´m trying to do:
Navigate/Route/(select Route by long press)/edit/
now you can see the route on screen, but there is no possibility to swipe or even export the route or rows.
B21
Re: Print FP
Postby kitercuda » 21 Apr 2015, 19:26
Menu/Tools and info/logbook
or long press logbook Value (LOG) at the main window.
Re: Print FP
Postby B21 » 22 Apr 2015, 07:00
O.K. I understand.
This is what I have to do for copying the logbook datas.
But I want to copy the datas of the planned route to create and print a Flight Log.
I mean the datas of the route as you can recognise it on the screen if you go like this for instance:
best regards
B21
