Cannot import GPX
Cannot import GPX
Postby neusat » 04 Nov 2014, 15:51
Dear, I am using FlyLogicalWeb for programming navigation. FlyLogicalWeb export an open-standard GPX file, including way-points data, but, when I try to import this GPX file to FlyisFun, it does not import any way-point.
Here is a FlyLogicalWeb GPX example:
<?xml version="1.0" encoding="utf-8"?>
<gpx xmlns="http://www.topografix.com/GPX/1/1">
<rte>
<rtept lat="-38.9490013123" lon="-68.1557006836">
<magvar>3</magvar>
<name>SAZN (Presidente Peron)</name>
</rtept>
<rtept lat="-38.77001776526603" lon="-67.94263979287797">
<magvar>2.7</magvar>
<name>LI Pelegrini</name>
</rtept>
<rtept lat="-38.274369298965595" lon="-67.79835670385171">
<magvar>2.3</magvar>
<name>LD Casa Piedra</name>
</rtept>
<rtept lat="-37.81245394571596" lon="-67.66525626182556">
<magvar>1.9</magvar>
<name>RWY 25 mayo </name>
</rtept>
</rte>
</gpx>
Is there any problem with GPX format?
Thanks.
neusat
Re: Cannot import GPX
Postby kitercuda » 07 Nov 2014, 14:11
Format is OK.
Import the route to route's list!
- Open the Route list (Menu/Navigate/Routes or tap aircraft symbol at the centre of compass rose or ...)
- Menu / Import
