Route dialog box info disappeare
Postby FCH » 30 May 2014, 15:25
Hi, everybody.
1. of all: Very well designed Navigator.
Just a problem:
If switching to the Route Dialog Box of the Active Route the App will lock out and disconect from GPS it self.
The result will be, that the Informations (ET, ETA, UTC ....) of all waypoints will disappeare.
Afterwards, If switching back to the map, first the unlocker has to activate the App again.
Is this a normal procedure?
And is there a possibility to solve this problem?
Best regards and thanks
Frank
FCH
Re: Route dialog box info disappeare
Postby kitercuda » 01 Jun 2014, 18:26
I can you described your problem more? What are you exatly doing?
When switching back from Route dialog, FIF does not call unlocker again (only when application launch or relaunch)
Postby FCH » 02 Jun 2014, 16:13
After launching the App during 2-3 sec. a smal text box appears with "unlocker active" in black background.
Aftrewards the App shows the Map and GPS will be activated.
If switching to "Navigate" >>"Route" to load and activate a filed Route, afterwards again a smal text box appear with "unlocker active" in black background, during 2-3 sec. .
Afterwards the App shows the Map again and GPS will be activated again. (probably GPS locked off during the procedure loading the route)
If switching to the "Route Dialog Box" the screen will show the "Active Route" with all the waypoints but without its informations (ET, ETA, UTC ....).
(seems to be that GPS locked off again during "Active Route")
By the way, the Summary will show astronomical length, duration and fuel
If switching back to the map again a smal text box appear with "unlocker active" in black background, during 2 sec or so.
Afterwards the App shows the Map again and GPS will be activated again. (seem to be that GPS locked off during the explained procedure)
Interesting:
If the flight simulator ist activ and switching to the "Route Dialog Box" the screen will show the "Active Route" with all the waypoints and but with its informations (ET, ETA, UTC ....).
But the rest is similar.
FCH
Postby FCH » 04 Jun 2014, 17:14
Oh sorry. I understand.
Exactly what I am doing when switching back to the map is touching onto the hardkey ("back") of the mobile device (smartphone).
Frank
FCH
