Very quick, 2 point Nav into a runway, setup tip(s)
Postby flyyyer » 28 Apr 2014, 07:55
Ver 14.65 has a very useful 2 point nav feature.
To save that extra few vital seconds and clicks, here is how to set a very quick, 2 point mini route, with the added ability of having a chosen designated runway/ILS as the second point.
6 clicks and you are there:
On the map screen....
(MAP) Short tap on your DESTINATION airport
(DIALOG) Short tap at the top airport ICAO designator (This gives you the option to select a runway/ILS)
(LIST) Short tap on your chosen runway
(MAP) Short tap on your first navigation point (VRP, beacon , approach fix, etc.)
(DIALOG) Short tap on "Nav 2" button
(nav1/nav2) Long tap on the nav1/nav2 Dialog box on the screen. (This sets the order correct on nav1/nav2)
This works great under pressure for when things change as you are approaching an airport and is also very quick for a 2 point mini route but with added option of an end runway.
Re: Very quick, 2 point Nav into a runway, setup tip
Postby marpdiaz » 28 Apr 2014, 13:23
Nice hint.
thanks
Postby flyyyer » 29 Apr 2014, 09:12
Do you tend to fly a short hop to you next local airport for breakfast or out to a favourite spot and back?
Why not setup a quick , out from one runway and into the destination airport runway with the option of a quick return to base using the Nav1/Nav2 feature.
Tip 2
7 clicks and you are there:
(MAP) Short tap on your DEPARTURE airport
(LIST) Short tap on your departure runway
(MAP) Short tap on your DESTINATION airport (DIALOG)
(LIST) Long tap on your departure runway
(LIST) Short tap on "Nav 2" button
DONE
At any time....
Long tap on the nav1/nav2 Dialog box on any screen at any time, reverses the order on nav1/nav2
This gives the option of a departure check out of the correct runway/flying straight out check, then when you are ready, long press at the Nav1/Nav2 and you are then directed to your destination airport and runway. At any time in flight (or on your return) you can long press the Nav1/Nav2 to flip back to your home airport where the runway is already set for you. :-)
